![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
 Next:  1.4 The module APNOPO
Up:  1.3 Main ideas
 Prev:  1.3.3 Modification of the numbers
Index
Contents
Generally speaking, modules responsible for the creation and modification of meshes only consider geometrical meshes (i.e. nodes=vertices). For certain finite elements, the nodes may differ from the vertices. Consequently, once the geometric mesh is completed, the non-vertex nodes can be introduced. For example:
Module ADPNOP (keyword ADPO) performs this prescription.
