![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
 Next:  2.2 Methodology
Up:  2 Three-dimensional mesh generation (1)
 Prev:  2 Three-dimensional mesh generation (1)
Index
Contents
The MODULEF library proposes the following algorithms for three-dimensional meshes:
-  methods corresponding to a manual approach,
-  a transport-projection function (or algebraic method),
-  a translation-stacking or extrusion technique  (for topologically cylindrical domains),
-  a finite difference type mesh generator (for topologically hexahedral domains),
-  a multi-block method, and
-  a surface mesh generator for certain configurations.
Module  APNOP3, called directly, or via  the preprocessor  APN3XX, performs the following
functions:
-  generates three-dimensional meshes, for simple cases,  from the point and two-dimensional mesh data,
 using the  mesh algorithms. For complex domains, the mesh is generated by calling the appropriate modules
directly (see chapter 3);
-  restores the  NOPO data structures (or D.S.), containing the meshes created, in main memory
(in particular, using the methods described in chapter 3);
-  modifies and combines these meshes to form new meshes, along with their corresponding D.S.  NOPO,
which can be saved on sequential file.
Index
Contents
