![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
 Next:  3.2.4 Module COLIBR
Up:  3.2 Multi-block method
 Prev:  3.2.2 Calling of module COLIB2
Index
Contents
The derived modules are constructed using  COLIB2 for the case where there is only one single
block of a given type. There are consequently 3 derived modules:
  COLIBT ,  COLIBP  and  COLIBH  corresponding to the
case of a single tetrahedron, pentahedron or hexahedron.
The data is of the same type as above, but is simpler to enter because some data is implicitly known.
There are two options  to assign reference numbers: the one indicates that all these numbers will
be set to 0, and the other allows a distinct number to be assigned to each item created.
-  dimension array  M (in the blank common)
-  declare the integer arrays IDECAR(6) and NBPARE(6)
-  declare the real arrays XYZ(3,4) and XYZINT(3,LINT) where LINT is the total number
 of control points input by the user in the 6 coarse edges
-  call  INITI
-  call the module
  CALL COLIBT (M,NFNOPO,NINOPO,XYZ,IDECAR,NBPARE,XYZINT,
 .  IREF,NDSDE)
where
 -  M is the super array,
-  NF(NI)NOPO is the support number of  O.D.S.  NOPO and its level,
-  XYZ(3,4) are the coordinates of the 4  coarse vertices
-  IDECAR(I) is the splitting code of the edge: 0 for a straight edge split automatically into segments of
the same length;  1 if we input the intermediate points (see  XYZINT)
-  NBPARE(I) is the number of control points to create  on the edge (end-points excluded)
-  XYZINT(3,.) are the coordinates of the control points of the edges input by the user. For each edge I
 for which  NDECAR(I) = 1, we enter these values as follows:
XYZINT(J,I) is coordinate  J of point I, where I is the global number of the point; we first count the points
(end-points excluded)  of the first edge thus described, followed by those of the second, etc.
-  IREF is the option for assigning the references: 0 : all references are set to  0; 1 :
each item is differentiated: the vertices from 1 to 4, the edges (and their control points) from 5 to 10,
the faces (and the points created on them) from 11 to 14.
-  NDSDE is the sub-domain number (of all the sub-elements created)
 Remark:
-   To change one or several reference numbers (IREF=1), use module
 MODNOP ( MODNXX) or keyword  NUME of  APNOP3 after the introduction of the mesh
(keyword  INTR of  APNOP3).
-  declare the integer arrays IDECAR(9) and NBPARE(9)
-  declare the real arrays XYZ(3,6) and XYZINT(3,LINT) where LINT is the total number
 of control points  on the 9 coarse edges input by the user
-  call  INITI
-  call the module
 CALL COLIBP (M,NFNOPO,NINOPO,XYZ,IDECAR,NBPARE,XYZINT,
 .  IREF,NDSDE)
where
-  XYZ(3,6) are the coordinates of the 6 coarse vertices
-  IDECAR(I) is the splitting code of edge I: 0 for a straight edge split automatically into segments of
each item is differentiated: the vertices from 1 to 6, the edges (and their control points) from 7 to 15,
the faces (and the points created on them) from 16 to 20.
 Remark:
-  declare the integer arrays IDECAR(12) and NBPARE(12)
-  declare the real arrays XYZ(3,8) and XYZINT(3,LINT) where LINT is the total number
 of control points input by the user on the 12 coarse edges
-  call  INITI
-  call the module
 CALL COLIBH (M,NFNOPO,NINOPO,XYZ,IDECAR,NBPARE,XYZINT,
 .  IREF,NDSDE)
where
-  XYZ(3,8) are the coordinates of the 8 coarse vertices
each item is differentiated: the vertices from 1 to 8, the edges (and their control points) from 9 to 20,
the faces (and the points created on them) from 21 to 26.
 Remark:
Index
Contents
