![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
 Next:  1.3 Main ideas
Up:  1 Two-dimensional mesh generation
 Prev:  1.1 Introduction
Index
Contents
In the two-dimensional case, it corresponds to (according to the MODULEF approach):
-  generating meshes from point, line, contour, course mesh, etc., data,  using the appropriate
 algorithms;
-  modifying existing meshes and combining them to form the final mesh,   step by step,  to which a
D.S. of type  NOPO is associated. This D.S. is then stored in a sequential access file.
In order to achieve the above steps, we need to:
-  locate all the  primal sub-sets in the domain by eliminating all sub-sets which can be derived by
 symmetry, translation, etc., or more generally, by geometric transformation;
-  record, furthermore, the primal sub-sets linked to physical type constraints;
-  search for the module which is the most suitable for each of these sub-sets;
-  determine the nature of the data which each of these modules use;
-  construct the data from the points and lines present;
-  activate the desired  mesh generator(s);
-  perform the symmetries, translations, rotations, etc., of the primal sub-sets;
-  "glue" these meshes together, two by two;
-  repeat the two previous steps until the entire domain is covered;
-  perform some local or global transformations (refinement, regularization, etc.);
-  define the non-vertex  nodes, if necessary, and remove the vertices from the nodal list;
-  renumber, if necessary, the elements and/or nodes;
-  store the result on file (and plot it to verify and ensure the quality of the mesh).
For each primal sub-set, we select the  module which is most suitable:
-  for a deformed quadrilateral or triangle, modules  TRICOO and  QUACOO
(algebraic methods ) generates quadrangles, which can be split into triangles,
 and triangles;
-  for an arbitrary domain, modules  TRIFRO and  TRIHER (advancing-front method
 and Voronoi's method )  generates triangles;
-  similarly,  COLIB2 (multi-block method ), in the 2D version,
 produces the same result from a partitioning of a course mesh  of the domain.
-  when the elements to be created are few or identical, module  CONOPO
(manual method ) could be used;
-   CONOPO is suitable to mesh lines into segments;
-   MAOBJE is used to treat catalogued objects.
Index
Contents
