![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
 Next:  5.2 A two-dimensional example
Up:  5 Tutorial examples
 Prev:  5 Tutorial examples
Index
Contents
In order to become acquainted with the mesh construction and modification modules, the reader is referred to the
relevant chapters depending on his/her need:
-  Chapter 1 which gives a complete example of the utilization of module  APNOPO via its
preprocessor  APNOXX;
-  Chapter 2 which  gives a complete example of the utilization of module  APNOP3 via its preprocessor
 APN3XX;
-  Chapter 3 which contains examples of utilizing modules  COLIB2, COLIBR and preprocessor  COLIXX,
module  MA2D3E and its preprocessor  MA23XX and, lastly, of module  GEL3D1.
In the present chapter two supplementary examples are given. For each, and for the domain under consideration, the
different  steps  to be followed in the mesh creation process are described in full. We therefore present:
-  a description of the domain to be meshed;
-  the analysis of this domain from a geometric point of view, in particular by taking the
features of the mesh generators and the tools for transforming the possible meshes into account;
-  the results of the above analysis and a flow-chart of the operations to be performed;
-  the input data (the data file to be created);
-  calling the module and a print-out of the execution steps;
-  a plot of the resulting meshes.
Index
Contents
