![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
 Next:  1.3.3 Modification of the numbers
Up:  1.3 Main ideas
 Prev:  1.3.1 The  NOPO data structure
Index
Contents
There are two options to describe a curve which the mesh approximates:
where
A typical example of function FFRONT is given below:
      FUNCTION FFRONT(I,X,Y)
      IF ( I .EQ. 1) THEN
         FFRONT = function(X,Y)
      ELSE IF ( I .EQ. nnn )
         FFRONT = ...
      ELSE IF ...
      END IF
      END
A typical example of a function parser, for example the description of the line with reference 1 by a function, is the following:
The first case corresponds to writing a FORTRAN function and linking it at execution. In the second case, the curves are given in a data file, thus avoiding performing a link.
