Tiki Installer Disabled
As a security precaution, the Tiki Installer has been disabled. To re-enable the installer:
  1. Use your file manager application to find the directory where you have unpacked your Tiki and remove the lock file which was created in the db folder.
  2. Re-run tiki-install.php.
TikiWiki
