![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
Next: Print command: prf_f3d
Up: Part IV: Appendices
Prev: E Link library list
Contents
- apollo
- : apollo in different modes
- spectrum_apollo
- : versatek (inria-apollo spectrum software)
- spectrum_versaplot
- : versatek(spectrum with versaplot software)
- v80_apollo
- : versatek (inria-apollo 80 software)
- benson
- : benson output only
- brigitte
- : brigitte (SIMULOG graphics software)
- gks_plot10_entree
- : plot10 - gks v3 metafile (input possible)
- gks_plot10
- : plot10 gks v3 metafile
- gks_gral
- : peripheral using gksgral
- gks_gral_metafile
- : define the actions for a metafile (on exit) gksgral
- gks_sun
- : gks for Sun on exit
- hpgl
- : hp-gl plotting array
- ibm_gddm
- : ibm-gddm environment
- imprimante
- : printer
- phigs_apollo
- : phigs for Apollo on exit
- postscript
- : postscript (black and white or color) version 2.07
- silicon
- : silicon graphics (input possible)
- sun_core
- : sunCORE (input possible)
- sun_pixrect
- : sunview pixrect (input possible)
- tektronix_4014
- : tektronix 4014 (direct generation of the code)
- tektronix_plotter
- : plotter tektronix (quasi compatible 4014)
- tektronix_plot10
- : tektronix (software plot 10) (input possible)
- tektronix_4107
- : tektronix 4107 (input possible)
- tektronix_4105
- : tektronix 4105 (input possible)
- vax
- : vaxstation under uis (input possible)
- x11
- : X_WINDOW version 11 (input possible)
Remarks:
- it is advised to use the graphic peripherals x11 and postscript.
- peripheral x11 on HP/Apollo
- : To have X11 without the display manager on APOLLO, set:
wmgr -off (DM command)
followed by:
xownroot -on (shell command)
and at the end, reset:
xownroot -off
followed by:
wmgr -on
- postscript peripheral
To cater for color, 16³ = 4096 levels are used in file perifd.f.
It is thus necessary to modify parameter MAXCOL in the subroutines calling sub-program
inqtbc (library ft3d).
For example, you need to modify line 21 in sub-program iiniso of library
trac as follows:
PARAMETER(MAXCOL=6666)
Contents
