![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
Next: 3 Three-dimensional mesh generation (2)
Up: 2 Three-dimensional mesh generation (1)
Prev: 2.7 A complete example
Index
Contents
- POIN : Definition of the characteristic points.
- INTR : Introduction of a mesh residing on file into main memory.
- MA23 : Stacking using a 2D mesh.
- SU23 : Surface from a 2D mesh.
- MANU : Call the manual mesh generator.
- OBJE : Call the mesh generator for a single element.
- TRAN : Translation of a given mesh.
- ROTA : Rotation of a given mesh.
- SYMP : Symmetry with respect to a plane of a given mesh.
- DILA : Dilation of a given mesh.
- TETR : Split each element of a mesh into tetrahedra.
- RETR : Split each element of a mesh into sub-elements of the same type.
- NUME : Modification of attributes (reference or sub-domain number) in a mesh.
- RECO : "Glue together" two meshes.
- ADPO : Definition of nodes in a given mesh.
- EXTR : Extraction of the faces with given reference numbers.
- RENE : Renumbering of the elements of a mesh.
- RENC : Renumbering of the elements and nodes of a mesh.
- COUL : Renumbering of the elements by coloring.
- SAUV : Store a mesh resident in main memory on file.
- INTR : Introduce a mesh resident on file into main memory.
- TUER : Delete one or several NOPO data structures in memory.
- IMPR : Print the contents of a NOPO data structure.
- DESS : Plot a mesh.
- FIN : End of job.
Index
Contents
