Next: 1.3 The algorithms
Up: 1 Direct methods
Prev: 1.1 Introduction
Contents
This part gives a presentation of the different modules currently available in the code, along with their utilization context and parameters. Concrete computational examples are given in chapter 6.
Call the module:
CALL ASEMBV(M,NOT,NDSM,NCODSB,NFTAE,NITAE, + NFNDL1,NINDL1,NFB,NIB,NTB)
where:
Call the module:
CALL ASMAPS(M,NOT,NFTAE,NITAE,NFNDL1,NINDL1, + NFMUAE,NIMUAE,NFMUAS,NIMUAS)
where
Call the module:
CALL ASMBMS(M,NOT,NDSM,NCODSB,NFTAE,NITAE, + NFNDL1,NINDL1,NFB,NIB,NTB)
where:
Call the module:
CALL ASSMUA(M,NOT,NFTAE,NITAE,NFNDL1,NINDL1, + NFMUAE,NIMUAE,NFMUAS,NIMUAS)
where:
Call the module:
CALL CHOLPC(M,EPS,NENTRE,NFNDL1,NINDL1, + NFMUAE,NIMUAE,NFMUAS,NIMUAS,NRETOU)
where:
Call the module:
CALL CHOLPS(M,EPS,NENTRE,NFNDL1,NINDL1, + NFMUAE,NIMUAE,NFMUAS,NIMUAS,NRETOU)
where:
Call the module:
CALL CLIMPC(M,NIVO,VTG,NFNDL1,NINDL1, + NFMUAE,NIMUAE,NFBE,NIBE,NFBDCL,NIBDCL, + NFMUAS,NIMUAS,NFBS,NIBS)
where:
Call the module:
CALL CLIMPS(M,NIVO,VTG,NFNDL1,NINDL1, + NFMUAE,NIMUAE,NFBE,NIBE,NFBDCL,NIBDCL, + NFMUAS,NIMUAS,NFBS,NIBS)
where:
Call the module:
CALL CONDL1(M,NNSEG,NFMAIL,NIMAIL,NFNDL1,NINDL1,LNOET, + NNOMAX,ND,NDLMAX)
where:
On exit the module returns:
Call the module:
CALL CROUPC(M,EPS,NENTRE,NFNDL1,NINDL1,NFMUAE, + NIMUAE,NFMUAS,NIMUAS,NRETOU)
where:
Call the module:
CALL DRCHPC(M,NIVEAU,NCLRL,NFNDL1,NINDL1, + NFMUA,NIMUA,NFBE,NIBE, + NFBDCL,NIBDCL,NFBS,NIBS)
where:
Call the module:
CALL DRCRPC(M,NIVEAU,NCLRL,NFNDL1,NINDL1, + NFMUA,NIMUA,NFBE,NIBE, + NFBDCL,NIBDCL,NFBS,NIBS)
where:
Call the module:
CALL DRGAPC(M,NIVEAU,NCLRL,NFNDL1,NINDL1, + NFMUA,NIMUA,NFBE,NIBE, + NFBDCL,NIBDCL,NFBS,NIBS)
where:
Call the module:
CALL FRONT(M,NFFRON,NFTAEM,NITAEM,NFTAES,NITAES, + NFGAUS,NFBDCL,NIBDCL,NFB,NIB,NTB, + NFNDL1,NINDL1,NTYPFR,LF, + NOT1,NOT2,NDSM,EPS,VTG)
where:
Call the module:
CALL GAUSPC(M,EPS,NENTRE,NFNDL1,NINDL1, + NFMUAE,NIMUAE,NFMUAS,NIMUAS,NRETOU)
where:
Call the module:
CALL PREPAC(M,NNOMAX,ND,NDSM,NCLRL,NCODSA,NTY, + NFMAIL,NIMAIL,NFNDL1,NINDL1, + NFBDCL,NIBDCL,NFMUA,NIMUA,NTMUA, + LBDP,LBDPDL,MCNDL1,MCMUA,MCB)
where:
Call the module:
CALL PREPAF(M,NFMAIL,NIMAIL,NFFRON,LFRON,NTYPFR,LF)
where:
