Next: 3.2.6 Some utilization examples
Up: 3.2 Multi-block method
Prev: 3.2.4 Module COLIBR
Index
Contents
This preprocessor is used to create a command file of the same type as preprocessors APNOXX,
APN3XX , etc. This file is completed by a set of question/responses and contains
the following values:
- the job title
- IMPRE, NINOPO and NOMFIC: the print parameter, the level of the D.S. to construct and the file name.
- NBS, NA, NBGRO, IMPRE, NBFR and NDIMS as for COLIBR
- NBS cards containing the description of the coarse vertices:
- I, NOREF, XYZ(1:3) as for COLIBR
- NA cards containing the description of the coarse edges:
- I, NS1, NS2, IDEC, NPC , NOREF as for COLIBR
- XYZINT(1:3,1:NPC): the coordinates of the control points of the edges input if
IDEC = 1, XYZINT(J,K) is the coordinate J of point K of the edge with K = 1, NPC
- NBFR cards containing the description of the coarse faces
- NOREF, NCGE and LISTE(1:NCGE) as for COLIBR
- the NBGRO cards containing the description of the coarse blocks
- I, NCGE, LISTE(1,.), NCGED and NDSDE as for COLIBR
Remarks:
- In the present version NCGED = NCGE.
- COLIXX creates the data cards for COLIBR (it suffices to delete the first four lines of the file
generated automatically by COLIXX).
Index
Contents
