Next: Part IV: Appendices
Up: 5 Management under UNIX
Prev: 5.3 Description of commands
Contents
In order to perform the MODULEF up-date with Unix, we will deliver a file containing the up-date ( $MR/ascii/sta/etc/maj.fo) by e-mail.
This file must be stored in the directory $MR/ascii/sta/etc
The re-update is performed using the UNIX command patch. This
command considers the differences
produced, for example, by command diff)
between files and applies these differences to the original file, thus creating a new version.
A C program ( prepatch) which reads file maj.fo (containing the differences) and calls command patch has been written.
Command patch is used with options -c et -N ; these options allow us to enforce the command to interpret the modifications as output from command diff, and ignore the modifications once they have been applied.
All the messages generated during the call of the patch procedure are stored in file patch.log.
Now that you have received the package, go to directory containing the Makefile of the re-update:
cd $MR/ascii/com.util/patch
The Makefile assumes that variable MR is initialized correctly in the current environment; if this is not the case at the time when the make command is called, add the option:
-e MR= name of the directory where MODULEF has been installed
During execution of the Makefile, updating the MODULEF source code, it is assumed that the patch command is not available on your machine. The Makefile performing the update can therefore correspond to two situations:
which patch and/or man patch
Depending on the two possibilities, we will now indicate the way in which the Makefile must be called:
su root make patch -e Install=install ^D
The patch command is then stored in directory /usr/local/bin (in general), and the man is installed.
If you cannot login at the root, you need to execute
command:
make patch
The patch command is then created in directory
$MR/ascii/com.util/patch/patch-2.0.12u7
make
make patch and make respectively.
cd $MR/make/Install$MM
make librairies
make executables
The command's source and complementary information are given in directory:
$MR/ascii/com.util/patch/patch-2.0.12u7 (file README).
If, on HP/Apollo or Sun4, the Makefile to create the patch is interrupted during execution of
command file Configure, you can try to restart the
Makefile (make patch) by first executing the command:
make init_apollo if you work on HP/Apollo
make init_sun4 if you work on Sun4
Execution of target init_xx will enable you to avoid executing command file Configure (see documentation on patch command), and we then use a configuration which was established beforehand.
