Next: 1 Introduction
Up: Part III: Installation
Prev: Part III: Installation
Contents
If you are working on a UNIX machine ,
follow the procedure given below to install MODULEF using a magnetic tape:
where xxx is the directory where you wish to install MODULEF
restore a magnetic tape (approximately 25 MB)
start of the installation
The above procedure corresponds to reading a tape. However, if you are reading a cartridge instead of a tape, step 2 is modified as follows:
The tape, or cartridge, consists of two directories:
If you encounter problems, or if you would like more details regarding the installation process, consult Part iii of this user guide, in particular chapter 2 and Appendix D.
