Next: 5.2 Manipulating characters
Up: 5 Diverse utilities
Prev: 5 Diverse utilities
Index
Contents
Two utilities are considered: INITI and INITIS, where the latter is usually called.
SUBROUTINE INITI(,
INTEGER M(LM), LM, IMPRE, NNN
This utility prompts the user to input a title, then calls INITIS with the same parameters. It is most often preferable to call INITIS directly (the title is only used by some visualization programs).
SUBROUTINE INITIS(,
where
These print parameters may be modified during execution by the free format commands: !BAVARDAGE and !ADRESSAGE (section 1.1.5).
- IMPRE
- is the print parameter, from 0 to 10, and
- NNN
- = 1 to output each addressing, otherwise 0.
This utility must be called once only, at the start of the execution of the MODULEF program. Its aim is to initialize the variables required by other utilities (free format, dynamic storage, ...).
