![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
Next: References
Up: A Notation
Prev: A.1 Presentation of the utilities
Index
Contents
The most frequent parameters are defined once only below.
The abbreviation, tysd represents the
DS type. For example, instead of
NFtysd, read NFNOPO if the DS is of type NOPO.
- DM
super-array, considered as being of type
DOUBLE PRECISION (see M, XM).
- IATAB
"address" of a dynamic array, i.e.index in the super-array M
(the first element of this array is M(IATAB)).
- IC
or ICtysd
address in M of array % of a DS.
- LM
length (in words) of the super-array M.
- LTAB
length (in words) of a dynamic array.
Attention with double precision arrays
(section 3.5).
- LZ
or LZtysd
length (in words) of array NZ.
- M
INTEGER (see XM, DM).
- NBREMO
number of words occupied by a
scalar of given type
(utility TYPMOT, p.
- NC
or NCtysd
name of array % of a DS,
- NF
or NFtysd
file number of a DS.
- NI
or NItysd
level number of a DS.
- NTAB
coding of TAB in INTEGER form
(with the help of utility ICHAR4, p.
- NTYSD
coding of TYSD in INTEGER form
- NTYTAB
dynamic array type:
1 integer,
2 real single precision,
3 logical,
4 Hollerith (code 4 characters per word
5 real double precision,
6 complex,
7 complex double precision (not portable).
- NZ
or NZtysd
local copy of array % of a DS,
- TAB
dynamic array name.
This name is type
CHARACTER*l, with
- TYSD
DS type, in form CHARACTER*4.
For example: 'NOPO', 'MUA ', 'B '.
- XM
super-array, considered as being type
REAL (see M, DM).
Next: References
Up: A Notation
Index
Contents
