![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
Next: A.2 Usual parameters for the utilities
Up: A Notation
Prev: A Notation
Index
Contents
The utilities are presented in the following manner:
SUBROUTINE UTILIT(
INTEGER IN, INOUT
REAL OUT
Description of the utility...
This presentation includes a title, the Fortran specification of the utility, and
its description in natural language.
The arrows indicates the input/output mode of the parameters:
- IN
- is an input parameter, i.e.
used but not modified,
- OUT
- is an output parameter, i.e.
not used but modified,
- INOUT
- is an input and output parameter, i.e.
used and modified.
with the following definitions:
- a parameter is called used if its value before the call
can be used during execution of the utility,
- a parameter is called modified if its value can be
modified during execution of the utility.
Up: A Notation
Prev: A Notation
Index
Contents
