![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
 Next:   The EMC˛
  preprocessor
Up:  1.4 The module APNOPO
 Prev:  1.4.4 A complete example
Index
Contents
- COUR
-  Definition of the curves present in the domain via a function parser.
- POIN
-  Definition of the characteristic points.
- LIGN
-  Definition of the characteristic lines from the characteristic points.
- QUAC
-  Call the algebraic mesh generator for a generalized  quadrilateral.
- TRIC
-  Call the algebraic mesh generator for a generalized  triangle.
- TRIA
-  Call the advancing-front mesh generator for an arbitrary domain.
- TRIH
-  Call the Voronoï mesh generator  for an arbitrary domain.
- MANU
-  Call the manual mesh generator.
- OBJE
-  Call the mesh generator for a single element.
- BARR
-  Call the mesh generator to create segments from a contour.
- TRAN
-  Translation of a given mesh.
- ROTA
-  Rotation of a given mesh.
- SYMD
-  Symmetry with respect to a line in a given mesh.
- DILA
-  Dilation of a given mesh.
- Q4T
-  Split each  quadrangle of a mesh into four triangles.
- RETR
-  Split each element of a mesh into sub-elements  of the same type.
- REGU
-  Regularization of a mesh by barycentering.
- AIGU
-  Remove obtuse angles from a mesh composed of triangles.
- AFFL
-  Refine a mesh locally around certain vertices.
- NUME
-  Modify attributes (reference or sub-domain number) in a mesh.
- RECO
-  "Glue together" two meshes.
- ADPO
-  Definition of nodes in a given mesh.
- EXTR
-  Extraction of the edges with reference numbers given.
- RENE
-  Renumbering of the elements of a mesh.
- RENC
-  Renumbering of the elements and nodes of a mesh.
- COUL
-  Renumbering of the elements by coloring.
- SAUV
-  Store a mesh resident in main memory on file.
- INTR
-  Introduce a mesh resident on file into main memory.
- TUER
-  Delete one or several data structures in memory.
- IMPR
-  Print the contents of a  NOPO data structure.
- DESS
-  Plot a mesh.
- FIN
-  End of job.
 Next:   The EMC˛
  preprocessor
Index
Contents
