![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
 Next:  1.4.5 Abbreviated list of the keywords
Up:  1.4 The module APNOPO
 Prev:  1.4.3 Implementation
Index
Contents
This example consists of studying the thermal behavior of an electric motor and, more precisely, its rotor. It contains symmetries, so that only one part needs to be examined.
The remainder of this section contains:
Figure 1.7:  Central part and conductor
The data file corresponding to module APNOPO is shown below. For a detailed description of how such a file is created, consult the MODULEF User Guide - 1, Part II.
'MESH EXAMPLE FOR A SNCF-RATP MOTOR                                  '
 COURBES
     1                                 $ IMPRE
 COURBE01(X,Y)=
       (X-.2125037)**2+(Y-.0569402)**2-.026*.026;
FIN
'POINT                                                               '
     2    55                            $ IMPRE NPOINT  $
$   NOP   NOREF(NOP)     X(NOP).            Y(NOP).  $
     1       0         0.000000E+00     0.000000E+00
     2       0         0.155000E+00     0.000000E+00
     3       0         0.154410E+00     0.135091E-01
     4       0         0.152645E+00     0.269155E-01
     5       0         0.149719E+00     0.401170E-01
     6       0         0.145000E+00     0.530000E-01
     7       0         0.140000E+00     0.660000E-01
     8       0         0.133500E+00     0.775000E-01
     9       0         0.126000E+00     0.890000E-01
    10       0         0.111850E+00     0.992000E-01
    11       0         0.109602E+00     0.109602E+00
    12       0         0.270000E+00     0.000000E+00
    13       0         0.268973E+00     0.235321E-01
    14       0         0.265898E+00     0.468850E-01
    15       0         0.260800E+00     0.698811E-01
    16       0         0.253500E+00     0.935000E-01
    17       0         0.244000E+00     0.115000E+00
    18       0         0.233500E+00     0.135000E+00
    19       0         0.220000E+00     0.156000E+00
    20       0         0.206200E+00     0.173700E+00
    21       0         0.190919E+00     0.190919E+00
    22       1         0.232500E+00     0.405000E-01
    23       1         0.223000E+00     0.330000E-01
    24       1         0.211000E+00     0.310000E-01
    25       1         0.198500E+00     0.350000E-01
    26       1         0.187000E+00     0.501065E-01
    27       1         0.237500E+00     0.636379E-01
    28       3         0.290000E+00     0.000000E+00
    29       3         0.205060E+00     0.205060E+00
    30       2         0.420000E+00     -.400000E-02
    31       2         0.420000E+00     0.000000E+00
    32       0         0.415250E+00     0.000000E+00
    33       0         0.415250E+00     -.420000E-02
    34       0         0.415250E+00     -.680000E-02
    35       0         0.414750E+00     0.000000E+00
    36       0         0.414750E+00     -.420000E-02
    37       0         0.413960E+00     0.000000E+00
    38       0         0.413860E+00     -.341000E-02
    39       0         0.409000E+00     -.341000E-02
    40       0         0.409000E+00     -.420000E-02
    41       0         0.406750E+00     0.000000E+00
    42       0         0.404540E+00     -.341000E-02
    43       0         0.404540E+00     -.420000E-02
    44       0         0.399540E+00     0.000000E+00
    45       0         0.399540E+00     -.341000E-02
    46       0         0.398750E+00     -.420000E-02
    47       0         0.398750E+00     0.000000E+00
    48       2         0.419234E+00     -.253590E-01
    49       3         0.289471E+00     -.175098E-01
    50       0         0.398250E+00     -.420000E-02
    51       0         0.392500E+00     -.420000E-02
    52       0         0.388040E+00     -.420000E-02
    53       0         0.382250E+00     -.420000E-02
    54       0         0.382250E+00     0.000000E+00
    55       0         0.360000E+00     -.217760E-01
'LIGNES                                                              '
     2    27                            $ IMPRE  NDLM   $
$   NOLIG NOELIG NEXTR1 NEXTR2 NOREFL NFFRON       RAISON $
       1      6      1      2      0      0     0.800000E+00
       2      6      1     11      0      0     0.800000E+00
       3     10      2     11      0     -2     0.100000E+01
       4     10      3     13      0      0     0.100000E+01
       5      2     14     13      0     -2     0.100000E+01
       6      4     14     22      0      0     0.100000E+01
       7      4     22     25      1     -1     0.100000E+01
    23                                  $ NOEL
    24                                  $ NOEL
       8      4      4     25      0      0     0.900000E+00
       9      2      3      4      0      0     0.100000E+01
      10      2      4      5      0      0     0.100000E+01
      11      3      5     26      0      0     0.900000E+00
      12      3     26     25      1      1     0.100000E+01
      13      3     22     27      1      1     0.100000E+01
      14      3     15     27      0      0     0.100000E+01
      15      2     14     15      0      0     0.100000E+01
      16     10     12     21      0     -2     0.100000E+01
      17      2     12     28      0      0     0.100000E+01
      18      2     21     29      0      0     0.100000E+01
      19     14     28     29      3     -2     0.100000E+01
      20      6     49     55      0      0     0.110000E+01
      21      4     48     30      2     -2     0.100000E+01
      22      9     30     53      0     -1     0.100000E+01
    34                                  $ NOEL
    33                                  $ NOEL
    40                                  $ NOEL
    43                                  $ NOEL
    46                                  $ NOEL
    51                                  $ NOEL
    52                                  $ NOEL
      23      7     28     54      0      0     0.900000E+00
      24      2     28     49      3      0     0.100000E+01
      25      9     48     55      0      0     0.100000E+01
      26      4     53     55      0      0     0.100000E+01
      27      2     53     54      0      0     0.100000E+01
'TRIH        '
     2     0     2     6     1          $ IMPRE LEVEL NUDSD NBRELI NS1L
 $ LIST OF THE CONTOUR LINES :
     4     5     6     7     8     9
     1     0     1                      $ NCOMP NBRINT IOPT $
     6                                  $ COMPONENT $
'TRIH        '
     1     1     2     4     1          $ IMPRE LEVEL NUDSD NBRELI NS1L
     8    12    11    10
     4                                  $ COMPONENT $
'TRIH        '
     1     2     2     4    -1          $ IMPRE LEVEL NUDSD NBRELI NS1L
     6    15    14    13
    -4                                  $ COMPONENT $
'RECOL                                                               '
    1    0    1    3  0.10000E-02    0  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'RECO        '
    1    3    2    4  0.10000E-02    0  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'SYMD        '
     1     4     1                      $ IMPRE LEVEL1 LEVEL2
     0     0                            $ NBNNF NBNNSD
 -0.26795E+00  0.10000E+01  0.00000E+00 $ A. B. C.
'RECO        '
    1    4    1    3  0.10000E-02    0  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'ROTA        '
     1     3     1                      $ IMPRE LEVEL1 LEVEL2
     0     0                            $ NBNNF NBNNSD
  0.20000E+02  0.00000E+00  0.00000E+00 $ TETA. X. Y.
'RECO        '
    1    3    1    4  0.10000E-02    0  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'SYMD        '
     1     0     1                      $ IMPRE LEVEL1 LEVEL2
     0     0                            $ NBNNF NBNNSD
 -0.87488E-01  0.10000E+01  0.00000E+00 $ A. B. C.
'RECO        '
     0     0                            $ NBNNF NBNNSD
'TRIH        '
     1     0     1     3     1          $ IMPRE LEVEL NUDSD NBRELI NS1L
 $ LISTE OF THE CONTOUR LINES :
     1     3     2
     3                                  $ COMPONENT $
'RECO        '
    1    0    3    4  0.10000E-02    0  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'TRIH        '
     1     0     2     4     1          $ IMPRE LEVEL NUDSD NBRELI NS1L
    19    18    16    17
     4                                  $ COMPONENT $
'RECO        '
    1    0    4    3  0.10000E-02    0  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'QUAC        '
     2     0     2     4     1          $ IMPRE LEVEL NUDSD NBRELI NS1L
    25    26    22    21
     9     0                            $ IMAX NQUAD
'TRIH        '
     1     1     2     5     1          $ IMPRE LEVEL NUDSD NBRELI NS1L
    20    26    27    23    24
     5                                  $ COMPONENT $
'RECO        '
    1    0    1    4  0.10000E-02    0  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'MANU        '
     1     1     3                      $ IMPRE LEVEL NE
     3     3    34    30    33          $ TYPE NUDSD NS1 NS2 NS3
     0     0     0                      $ NFA1 NFA2 NFA3
     3     3    33    30    32          $ TYPE NUDSD NS1 NS2 NS3
     3     3    30    31    32          $ TYPE NUDSD NS1 NS2 NS3
     2     0     0                      $ NFA1 NFA2 NFA3
'RECO        '
    1    4    1    5  0.10000E-02    0  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'MANU        '
     1     2    15                      $ IMPRE LEVEL NE
     3     5    33    32    38          $ TYPE NUDSD NS1 NS2 NS3
     3     5    38    32    37          $ TYPE NUDSD NS1 NS2 NS3
     3     5    40    33    38          $ TYPE NUDSD NS1 NS2 NS3
     3     5    40    38    39          $ TYPE NUDSD NS1 NS2 NS3
     3     6    39    38    37          $ TYPE NUDSD NS1 NS2 NS3
     3     5    43    40    39          $ TYPE NUDSD NS1 NS2 NS3
     3     5    43    39    42          $ TYPE NUDSD NS1 NS2 NS3
     3     6    39    37    41          $ TYPE NUDSD NS1 NS2 NS3
     3     6    42    39    41          $ TYPE NUDSD NS1 NS2 NS3
     3     5    46    43    45          $ TYPE NUDSD NS1 NS2 NS3
     3     5    45    43    42          $ TYPE NUDSD NS1 NS2 NS3
     3     6    45    42    44          $ TYPE NUDSD NS1 NS2 NS3
     3     6    42    41    44          $ TYPE NUDSD NS1 NS2 NS3
     3     5    46    45    47          $ TYPE NUDSD NS1 NS2 NS3
     3     5    45    44    47          $ TYPE NUDSD NS1 NS2 NS3
'TRAN        '
     1     2     0                      $ IMPRE LEVEL1 LEVEL2
     0     0                            $ NBNNF NBNNSD
 -0.16500E-01  0.00000E+00              $  X. Y.
'RECO        '
    1    5    2    4  0.10000E-02    0  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'RECO        '
    1    4    0    2  0.10000E-02    0  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'SYMD        '
     0     0                            $ NBNNF NBNNSD
  0.00000E+00  0.10000E+01  0.00000E+00 $ A. B. C.
'RECO        '
    1    0    2    1  0.10000E-02    0  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'ROTA        '
     1     1     2                      $ IMPRE LEVEL1 LEVEL2
     0     0                            $ NBNNF NBNNSD
  0.69230E+01  0.00000E+00  0.00000E+00 $ TETA. X. Y.
'ROTA        '
     1     1     4                      $ IMPRE LEVEL1 LEVEL2
     0     0                            $ NBNNF NBNNSD
  0.13846E+02  0.00000E+00  0.00000E+00 $ TETA. X. Y.
'RECO        '
    1    4    2    5  0.10000E-02    0  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'ROTA        '
     1     5     1                      $ IMPRE LEVEL1 LEVEL2
     0     0                            $ NBNNF NBNNSD
'RECO        '
    1    1    5    4  0.10000E-02    0  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'ROTA        '
     0     0                            $ NBNNF NBNNSD
'RECO        '
    1    2    4    5  0.10000E-02    0  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'RECO        '
    1    0    5    2  0.10000E-02   0  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'RECO        '
    1    3    2    5  0.10000E-02    0  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'TUER        '
     1     1                            $ IMPRE  NBRE DE SD NOPO TO KILL
     0                                  $ LEVEL
'TUER        '
     1                                  $ LEVEL
'TUER        '
     2                                  $ LEVEL
'TUER        '
     0     1                            $ IMPRE  NBRE DE SD NOPO TO KILL
     3                                  $ LEVEL
'TUER        '
     4                                  $ LEVEL
'SAUVER                                                              '
     2     5     0                      $ IMPRE NINOPO NTNOPO
 MAILLAGE.INTER                         $ FILE NAME
'END        '
