![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
 Next:  2.7 A complete example
Up:  2.6 Implementation of  module APNOP3
 Prev:  2.6.1 Callinglibraries and files
Index
Contents
 POIN  : Definition  of the characteristic points .
-  POIN   (A) :  the keyword to activate
-  IMPRE (I) : print parameter for execution
-  NPOINT (I) : number of points to describe
-  Loop from J=1 to NPOINT, the number of characteristic points
  -   NOP (I) : the point number
-   NOREF (I) : its reference
-   X (R) : the abscissa
-   Y (R) : the ordinate
-   Z (R) : the height
-  end  of loop J
 Remarks:
-  The points may be entered in any order (due to NOP).
-  If the points do not lend itself to a manual capturing (due to their number or position), but
are easier to capture via a subroutine, we can use subroutine  SPDPTS, which is called by module
 APNOP3. This is done by:
 INTR  : Calls module  SDREST to introduce  a mesh residing  on file into main
memory in order to modify it.
-  INTR   (A) : the keyword to activate
-  NINOPO (I) : the level of the D.S. to introduce into m.m.
-  NOM    (A) : the name of the file containing the D.S.
 Remark:
-  To be usable by the geometric modification modules,  the meshes introduced in this way must be of type
 P1, i.e., the nodes are the vertices.
 MA23  :  Calls module   MA2D3E to create a  3D mesh from the data of a  2D mesh of one of
the sections of the domain. The latter is thus topologically a cylinder defined by a stacking
  constructed from the given section.
-  MA23   (A) : the keyword to activate
-  NINOPE (I) : the level of the I.D.S. serving as data
-  NINOPS (I) : the level of the resulting O.D.S.
The data belonging to  MA23XX, the preprocessor which corresponds to module  MA2D3D,
then follows, to which we will return to later (chapter 3).
 SU23  :  Calls module  TN2D3D to create a surface  from the data of a
2D mesh.
-  SU23   (A) :  the keyword to activate
-  FONINT (I) : option to give the projection function defining the map from the 2D mesh to that
of the surface:
  -  0 : the projection function  F2D3D is given in the form of a subroutine (see chapter 4,
   module  TN2D3D);
-  1 : the function is input via a function parser,  i.e.  the data must be input in the following form
(see chapter 1, keyword  COUR):
     -   'X01(X,Y)  =   function of  X  and Y ;'
 the expression must be between ' and terminated with a ;
-   'Y01(X,Y)  =   function of  X  and Y ;'
-   'Z01(X,Y)  =   function of  X  and Y ;'
-  FIN(A) : indicates the end of data for this function
 Remark:
-  X01, Y01 and Z01 defines the coordinates (x,y and z) of the surface points from  those
(X  and Y) of the initial  mesh points.
 MANU  : Calls the mesh generator  CONOPO which corresponds to a manual description ,
 i.e., from points (keyword  POIN).
-  MANU   (A) : the keyword to activate
-  LEVEL (I) : the level of the resulting D.S.
-  NE (I) : the number of elements to create
-  Loop from J=1 to NE, the number of elements
-  end of loop J
 Remarks:
-  NUMSOM(*) is one of the points created with keyword  POIN.
-  The order of the vertices, edges and faces is the standard order of the D.S.  NOPO.
 OBJE : Calls the mesh generator  CONOPO corresponding to the case of a single element.
-  OBJE   (A) : the keyword to activate
-  NCGE (I) : the type of element: 1  point, 2 point, 2 segment,
     3 segment,
     3 triangle, triangle,
 4 quadrilateral,  5 quadrilateral,  5 tetrahedron,
     6 tetrahedron,
     6 pentahedron, 7 pentahedron, 7 hexahedron; hexahedron;
-  IREF (I) : reference  option
  -   0 : all references are set to  0
-   1 : the references are different:
    -  for the vertices:  1, 2, 3, 4, ..., n
-  for the edges: n+1, ..., n+p
-  for the faces: n+p+1, ...,
 Remarks:
-  The sub-domain number is set to 1.
-  The keyword   NUME can be used to modify the numbers.
-  This module is used when doing simple tests rapidly.
 TRAN  : Calls module   MODNOP to generate a mesh resulting from a translation  of a
given mesh.
-  TRAN   (A) : the keyword to activate
-  LEVEL1 (I) : level of the initial D.S.
-  LEVEL2 (I) : level of the resulting D.S.
-  NBNNF (I) : the number of reference numbers to change
-  NBNNSD (I) : the number of sub-domain numbers to change
-  Loop from J=1 to  NBNNF (if NBNNF  0) 0)-  NOLD(J) (I) : the reference number to change
-  NNEW(J) (I) : the number to assign to items referenced  by NOLD(J)
-  end of loop J
-  Loop from J=1 to NBNNSD (if NBNNSD  0) 0)-  NOLD(J) (I) : the sub-domain number to change
-  end of loop J
-  TRANX (R) : the x component of the translation
-  TRANY (R) : the y component of the translation
-  TRANZ (R) : the z component of the translation
 ROTA  : Calls module  MODNOP to generate a mesh resulting from a rotation  of
a given mesh.
-  ROTA   (A) : the keyword to activate
-  end of loop J
-  end of loop J
-  VX (R) : the first component of the axis of rotation
-  VY (R) : its second component
-  VZ (R) : its third component
-   (R) : the rotation angle in  degrees (R) : the rotation angle in  degrees
-  XC (R) : the abscissa of the center of rotation
-  YC (R) : the ordinate
-  ZC (R) : the height
 SYMP  : Calls module  MODNOP to generate the mesh resulting from  symmetry  with
respect to a plane in a given mesh.
-  SYMP   (A) : the keyword to activate
-  end of loop J
-  end of loop J
-  A (R) : the parameters defining the plane of symmetry given in the form
 AX + BY + CZ + D = 0.
-  B (R) : the second coefficient of the plane equation
-  C (R) : the third coefficient
-  D (R) : the fourth coefficient
 Remark:
 DILA  : Calls module  MODNOP to generate the mesh resulting from a dilation  of
given mesh.
-  DILA   (A) : the keyword to activate
-  end of loop J
-  end of loop J
-  DILX (R) : the dilation coefficient in the x direction
-  DILY (R) : the dilation coefficient in the y direction
-  DILZ (R) : the dilation coefficient in the z direction
-  XINV (R) : the abscissa of a point which is invariant by this transformation
-  YINV (R) : the ordinate
-  ZINV (R) : the height
 TETR : Calls  module  DTRI3D to split  each element of the given mesh
into tetrahedra.
-  TETR  (A) : the keyword to activate
 RETR  : Calls module   RETRIN to split  each element of a given mesh
into sub-elements of the same type.
-  RETR  (A) :  the keyword to activate
-  N (I) : the splitting parameter
 Remark:
-  Each element is split into  N³ elements of the same type  (N in the case of a segment,
 N² for triangles and quadrangles, or else N³).
 NUME  : Calls  module  MODNOP to modify attributes (reference or sub-domain numbers)
 in a given mesh.
-  NUME   (A) :  the keyword to activate
-  end of loop J
-  end of loop J
 RECO  : Calls module  RECOLC to "glue together"  two meshes to form a new mesh.
-  RECO   (A) : the keyword to activate
-  LEVEL1 (I) : level of the  first initial D.S.
-  LEVEL2 (I) : level of the second initial D.S.
-  LEVEL3 (I) : level of the resulting D.S.
-  EPS (R) :  the precision of the union (for example 0.01)
-  IOPT (I) : the gluing option: 0 geometrical, 1 physical.
-  end of loop J
-  end of loop J
 Remarks:
-  A geometrical "gluing together" consists of identifying the points by taking only  their
positions into account.
-  On the contrary, a physical "gluing together" consists of identifying the points by taking their
position and reference number
 into account  (two points are said identical if their positions and references are the same).
 ADPO  : Calls  module  ADPNOP  to define the nodes
of a given mesh (as opposed to a mesh for which the nodes are identical to the vertices).
-  ADPO   (A) : the keyword to activate
-  N1 (I) :  the number of nodes on the edges (endpoints excluded)
-  ISET (I) : the number of internal nodes in each triangle or triangular face
-  ISEQ (I) : the number of internal nodes in each quadrilateral  or quadrilateral face
-  ISETE (I) : the number of internal nodes in each tetrahedron
-  ISEPE (I) : the number of internal nodes in each pentahedron
-  ISEHE (I) : the number of internal nodes in each hexahedron
-  NOESOM (I) :
 1 : vertices are  nodes
 0 : if not
 Remarks:
-  It is no longer possible to activate the preceding keywords, consequently this keyword is called
once the entire geometry has been processed.
-  Renumbering is desired after this operation.
 EXTR  : Calls module   TRCOAC to construct a D.S.  NOPO containing the faces possessing a given
reference number.
-  EXTR   (A) : the keyword to activate
-  NBNNF (I) : the number of face reference numbers to consider
-  Loop from J=1 to NBNNF (if NBNNF  0) 0)-  NREF(J) (I) : the face reference numbers to  retain
-  end of loop J
 RENC  : Calls  module  GIBBS to renumber  the nodes of a mesh.
-  RENC   (A) : the keyword to activate
 Remark:
-  This keyword usually comes just before saving the final mesh on file.
 RENE  : Calls  module  GIBBS to renumber  the elements and the nodes of a mesh.
-  RENE   (A) : the keyword to activate
 Remark:
 COUL  : Calls module  COULE1 to renumber  the elements by coloring.
-  COUL   (A) : the keyword to activate
-  LVECT (I) : the maximum number of elements per color
-  NLC (I) : the number of curved  boundaries described
-  NOMTAB (A) : the name of the array to be associated with the D.S.
-  Loop from J=1 to NLC, the number of curved lines
    -  NREF(J) (I) the reference number of line J
-  end of loop J
 Remark:
-  This keyword is used to regroup the elements of a mesh into disjoint sets. Consequently, it
enables us to perform a calculation, for example of element matrices, on super-calculators.
 SAUV  : Calls  module  SAUVER to store  a mesh, residing in main memory, on file.
-  SAUV   (A) : the keyword to activate
-  NINOPO (I) : level of the  D.S. to be saved on file
-  NTNOPO (I) : the number of arrays to associate to the D.S. (usually  0)
-  NOM    (A) : the file name
-  Loop from J=1 to NTNOPO  (if  NTNOPO  0) 0)-  NOMTAB (A) : the name of array J (4 characters)
-  NTYP (I) : its type
-  LONG (I) : the number of   words
-  Loop from K=1 to the number of variables
    -   VAL(K) (NTYP) : the variables of the array
-  end of loop K
-  COMMENT (A) : comment regarding the contents of array J
-  end of loop J
 Remark:
-  This keyword may be activated at any time to save a partial or final mesh.
memory.
-  NINOPO (I) : the level of the D.S. after it is introduced into m.m.
 Remark:
-  In order to be usable by the geometrical transformation modules, a mesh introduced in this way
must be of type P1, i.e., their nodes and vertices must coincide.
 TUER  : Calls  module  TUERSD to remove one or several mesh data structures (D.S.) from memory.
-  TUER   (A) : the keyword to activate
-  NBRE (I) : the number of D.S. to "kill"
-  Loop from J=1 to NBRE
  -  LEVEL(J) (I) : the level of D.S. J to delete from the arrays
-  end of loop J
 Remark:
-  This keyword can be activated to economize on memory space.
 IMPR  : Call module  IMNOPO to print  the contents of a mesh data structure (D.S.).
-  IMPR   (A) : the keyword to activate
-  NINOPO (I) : the level of the D.S. to print
 DESS  : Calls  module  TRNOPO to plot  a mesh.
-  DESS   (A) : the keyword to activate
-  ITERM1  (I) : the terminal number in the nomenclature of  your
  installation of the software package F3D
-  ITERM2  (I) : set  0
-  IOPT  (I) : the mesh plotting option: 1 the edges, 2 the visible edges, 3 the invisible edges,
    4 the shrunken mesh, 5 the same, visible, 6 the same, invisible, 7 all the elements, 8 the same, shrunken.
-  LEVEL (I) : the level of the D.S. to plot
 Remarks:
-  The couple (ITERM1, ITERM2) defines the graphics device.
-  The  preprocessor  TRNOXX is more frequently used to plot meshes.
-  Consequently, by deleting this keyword from the  APNOP3 facilities, we avoid loading the
graphics libraries at the time the meshes are conceived.
 FIN : Request to terminate the job.
-  FIN   (A) : the keyword to activate
In addition, the following keywords are found in  preprocessor  APN3XX:
- LIRE
-  : request to read  another data file (of the same format).
- CONT
-  : request to suppress the data coherence controls .
- MENU
-  : request to obtain a  list of the keywords in the menu .
 Remarks
-  " ? ", or anything : has the same effect as keyword  MENU.
-  In case of an error, keyword  MENU is selected.
Index
Contents
