![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
 Next:  3.4.4 Examples of use
Up:  3.4 Method for a hexahedral topology
 Prev:  3.4.2 Description of the input data
Index
Contents
Different options are available to define the geometry, the splitting of the elements and the physical
attributes.
-  The  geometry: option IOPTM, arrays X,Y and H, functions F1, F2 and F3:
  -  IOPTM = 0: the mesh is of finite difference type with constant step in the  3 directions.
  X, Y and H are three real  values (declared as arrays)  which represent the 3 spacing steps in the 3
  directions. Every point, M, is referenced by its three indices I, J, and K and has coordinates:
-  IOPTM = 1: the mesh is of finite difference type  with variable  step in the 2 first directions
  and constant step in the third direction.
  X an Y are two arrays of lengths N1 and N2,  H  is  real (declared as an array); these values
  enable us to find the coordinates of each point, M, with indices I, J and K, as follows:
-  IOPTM = 2: the mesh is of finite difference type with variable step in the 3
  directions.  X, Y and H are three arrays of lengths  N1, N2 and NB+1; these values
  enables us to compute the coordinates of any point M, with indices I, J and K, as follows:
-  IOPTM = 3: the mesh is of finite difference type with variable step in the 2 first directions
    and a constant step in the third direction. X and Y are two arrays of length
   N1 N2 and H is  real (declared as an array); these values are used to compute
   the coordinates of any point M, with indices I, J and K, as follows: N2 and H is  real (declared as an array); these values are used to compute
-  IOPTM = 4: the mesh is of finite difference type with variable step in the 2 first directions
   and a variable step in the third direction.  X and Y are two arrays of length
   N1 N2 and H is an array of length NB+1; these  values are used to compute the coordinates of any
   point M, with indices I, J and K, as follows: N2 and H is an array of length NB+1; these  values are used to compute the coordinates of any
-  IOPTM = 5: a mesh of finite difference type with constant step in the 2 first directions
   used to construct the final mesh via the definition of points given by functions
   F1, F2 and F3.  X and Y are real (declared as arrays). we obtain the following construction:
   and
-  IOPTM = 6: a mesh  of finite difference type with variable step in the 2 first directions
    used to construct the final mesh via the definitions of the  points given by functions
   F1, F2 and F3.  X and Y are two arrays of lengths N1 and N2. We obtain the following construction:
   and
-  IOPTM = 7:  a mesh of finite difference type with variable step in the first 2 directions
   F1, F2 and F3.  X and Y are two arrays of lengths N1 N2. We obtain the following construction:
   and
-  IOPTM = < 0:  a mesh  of finite difference type with variable step in the 3 directions
    used to construct the final mesh via the definitions of the  points given by arrays
   with indices X, Y and H (without verification).
-  The  splitting of elements: option NOPTDE:
 -  NOPTDE = 0:  the result consists of hexahedra formed logically;
-  NOPTDE = 1:  each hexahedron is split into 2 pentahedra according to the direction
  of the first bisector in the  z=0 plane;
-  NOPTDE = 2: each hexahedron is split into  2 pentahedra according to the direction
  of the other diagonal;
-  NOPTDE = 3: we first follow case NOPTDE = 1, then each pentahedron  is split into 3 tetrahedra;
-  NOPTDE = 4: the same with option NOPTDE = 2;
-  NOPTDE = 5: each hexahedron is split into 5 tetrahedra.
-  The  physical attributes: sub-domain and reference numbers:
The point numbering is done according to the indications depicted in  figure 3.30.
The element numbering is done analogously, layer by layer.
Figure 3.30:  Point numbering  by module  GEL3D1
To call module   GEL3D1 , it is necessary to write a main program as follows:
-  dimension array M (in the blank common)
-  declare the integer array NUMAT(.), array with 2 or 3 indices according to the case
-  declare the integer array ITYP(NB) where NB is the number of layers
-  declare the real array X(.), array with 1, 2 or 3 indices according to the case
-  declare in the same way the real arrays  Y(.) and H(.)
-  declare the externals F1, F2 and F3 (according to the case)
-  call  INITI
-  call the module
 CALL GEL3D1 (M,IOPTM,JOPTSD,NOPTDE,N1,N2,NB,X,Y,H,
 .  F1,F2,F3,NUMAT,ITYP,NFNOPO,NINOPO,NFAUX)
where
 -  M is the super array
-  IOPTM is the data description option
-  JOPTSD is the sub-domain numbering option
-  NOPTDE is the element splitting option
-  N1 is the number of points in the x direction
-  N2 is the number of points in the y direction
-  NB is the  number of layers (i.e. the number of points-1 in the z direction)
-  X,Y and H are the arrays with 1, 2 or 3 indices to define the coordinates of the points
-  F1, F2 and F3 are the names of the 3 external functions to supply (according to the value of IOPTM)
  to define the point coordinates. These functions have the following form:
-  F1(I,J,XR,YR,K) defines the abscissis of the points from I  and J, the position of the point in the
 plane of definition,
XR and YR,  the coordinates of  point with indices I and J,  and K , the sectional index (i.e. K=1,NB+1)
-  F2(I,J,XR,YR,K) has the same form and defines the ordinates of the  points
-  F3(I,J,XR,YR,K)  has the same form and defines the sides of the points
-  NUMAT is an array with 2 or 3 indices to assign the sub-domain numbers
-  ITYP is the array determining the type of layers (array linked to NUMAT)
-  NF(NI)NOPO is the support number of the O.D.S.  NOPO and its level
-  NFAUX has the value 0
 Remark:
In order to change the references which are automatically assigned, either module  MODNOP, or
preprocessor  MODNXX, or the keyword  NUME of  APNOP3,  can be used.
Index
Contents
