![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
 Next:  4.3 Mesh modification modules
Up:  4 List of the modules
 Prev:  4.1 Introduction
Index
Contents
An alphabetic list of the mesh generation modules is given below:
If the given mesh consists of triangles and quadrilaterals in R³, the mesh generator creates the mesh of the corresponding surface.
This module can be employed as an interface for non-MODULEF meshes in order to make them compatible with the modules in this code after conversion into NOPO.
Dimension array M (in the blank common), call  INITI
 CALL CONOPO (M,M,NDIM,NE,NP,IADEX,IAREFS,IAREFA,
.  IAREFF,IACOOR,NFNOPS,NINOPS)
where
The user must address and complete the descriptive arrays in M, their addresses being passed as arguments of the module.
The arrays to complete are the following:
 .  This array contains:
 where NBAR(i) is the number of edges of element
 i.  This array contains:
 where NBFA(i) is the  number of faces of element
X(1), Y(1), X(2), Y(2), ... X(NP), Y(NP)
X(1), Y(1), Z(1), X(2), Y(2), Z(2), ... X(NP), Y(NP), Z(NP)
  if NDIM = 3
The order of the vertices, edges and faces is the standard order
 (see
[3] figure 4.1).
The module MAOBJE is a simplified version of CONOPO with NE=1.
Figure 4.1:  Local (ordered) numbering of the items
The only constraint is that the number of points present on 2 opposite sides must be equal.
The only constraint is that the number of points present on the 3 sides must be equal.
Dimension array M (in the blank common), declare the logical FONINT, call  INITI
 CALL TN2D3D (M,NFNOPE,NINOPE,NFNOPS,NINOPS,NTNOPS,
.  FONINT,F2D3D,NTRANS)
where
 3D ;
 3D ;  2D ;
2: mesh 1D
 2D ;
2: mesh 1D  2D ;
 2D ;
If NTNOPS > 0, it is necessary to input the associated arrays (see RECOLC).
Subroutine  F2D3D is defined as follows:
SUBROUTINE F2D3D (X,Y,X3,Y3,Z3)
where
Modules COLIB2 and MA2D3D can also be used to construct surfaces from different data.
tn22.psfig:tn2d3dInitial meshtn23.psfig:tn2d3d1Derived surface
The contour may contain several connected components. In addition, internal points can be fixed.
