Suiv.: Partie II: Graphiques
Sup.: 3 Manipulation de structures et divers
Préc.: 3.7 Valeurs et vecteurs propres d'une
Index
Table des matières
Compression d'une S.D. MUA (module CCMUA) ou AMAT (module CCAMAT).
SUBROUTINE CCMUA(M,RAPORT,NFMUAE,NIMUAE,NFMUAS,NIMUAS) C +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ C BUT : COMPRIMER LA S.D.E. MUA EN GARDANT LES SEULS COEFFICIENTS C --- A(I,J) DE CHAQUE LIGNE I AU DELA DU 1-ER SUPERIEUR OU EGAL A C ABS(A(I,I)) * RAPORT POUR I=1,...,NTDL C +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
où
SUBROUTINE CCAMAT(M,RAPORT,NFAMAE,NIAMAE,NFAMAS,NIAMAS) C ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ C BUT : COMPRIMER LA S.D.E. AMAT EN GARDANT LES SEULS COEFFICIENTS C --- A(IJ) TELS QUE ABS(A(I,J)) >= RAPORT * ABS(A(I,I)) I=1,...,NTDL C ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
où
