Modulefpreviousupnextcontentsindex[BIG][Normal][small]
Suiv.: Partie II: Graphiques Sup.: 3 Manipulation de structures et divers Préc.: 3.7 Valeurs et vecteurs propres d'une Index Table des matières
3.8 Divers
Compression d'une S.D. MUA (module CCMUA) ou AMAT (module CCAMAT).
      SUBROUTINE CCMUA(M,RAPORT,NFMUAE,NIMUAE,NFMUAS,NIMUAS)
C +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
C BUT : COMPRIMER LA S.D.E. MUA EN GARDANT LES SEULS COEFFICIENTS
C ---   A(I,J) DE CHAQUE LIGNE I  AU DELA DU 1-ER SUPERIEUR OU EGAL A
C       ABS(A(I,I)) * RAPORT POUR I=1,...,NTDL
      SUBROUTINE CCAMAT(M,RAPORT,NFAMAE,NIAMAE,NFAMAS,NIAMAS)
C ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
C BUT : COMPRIMER LA S.D.E. AMAT EN GARDANT LES SEULS COEFFICIENTS
C ---   A(IJ) TELS QUE ABS(A(I,J)) >= RAPORT * ABS(A(I,I)) I=1,...,NTDL
