Next: References
Up: Part IV: Appendices
Prev: Print command: prf_f3d
Contents
Files .profile et .cshrc enable you to constitute your own environment when logging yourself onto your machine.
File modulef.csh is used in a C Shell environment. A source file of it can be produced in file .cshrc, belonging to all MODULEF users, enabling the users to obtain the MODULEF environment.
An example of file modulef.csh:
# Csh environment # Example on HP/Apollo INRIA # # Assignment of the basis variables: setenv MM apollo setenv MR /udd2/modulef setenv MV sta # Assignment of other variables for abreviation: setenv mb $MR/ascii/com.util setenv ms $MR/ascii/sta/s setenv mo $MR/$MM/$MV/lib set path = ($path $MR/$MM/com.util $MR/$MM/$MV/bin) # Assignment of variables for the compilation and linking: # It is possible to have non-statisfied references during linking: # # F77 : compilation command for Fortran programs # OPTION_F77 : Fortran compilation option # CC : compilation command for c programs # OPTION_CC : c compilation option # LINK : link command # LINKR : link command with bit relocation # STDLIB : libraries to include when linking # DEST : optionto redirect the output file when linking # # setenv F77 f77 setenv CC cc setenv OPTION_F77 "-c -W0,-overlap,dd,dc,-indexl,-pic,-idir,$MR/ascii/$MV/s/include" setenv OPTION_CC '-c -W0,-indexl,-pic' setenv LINK 'ld -A noallres -A alllooks -A allmarks -a -r' setenv LINKR 'ld -r' setenv STDLIB '' setenv DEST '-W0,-b,' # Proposition for compilation and link commands on other machines # - RS6000 : # setenv F77 xlf ; setenv CC cc # setenv OPTION_F77 "-c -I$MR/ascii/sta/s/include" # setenv OPTION_CC "-c -I$MR/ascii/sta/s/include" # setenv LINK 'xlf' # setenv LINKR 'ld -r' # setenv STDLIB '-lX11 -lXext' # setenv DEST '-o ' # # - silicon : # setenv F77 f77 ; setenv CC cc # setenv OPTION_F77 "-c -G 3 -col77 -I$MR/ascii/sta/s/include" # setenv OPTION_CC "-c -G 3 -I$MR/ascii/sta/s/include" # setenv LINK 'f77 -G 3' # setenv LINKR 'ld -r' # setenv STDLIB '-lgl -lfgl -ldgl -lX11' # setenv DEST '-o ' # # - sun : # setenv F77 f77 ; setenv CC cc # setenv OPTION_F77 "-c -ansi -i4 -I$MR/ascii/sta/s/include" # setenv OPTION_CC "-c -I$MR/ascii/sta/s/include" # setenv LINK 'f77 -Bstatic' # (ou) setenv LINK 'f77 -Bdynamic' # setenv LINKR 'ld -r' # setenv STDLIB '-lsuntool -lsunwindow -lpixrect -lX11 ' # setenv DEST '-o '
