Modulefpreviousupnextcontents[BIG][Normal][small]
Next: D Installation: UNIX Up: Part IV: Appendices Prev: B.6 The general preprocessor TOUTXX Contents
C The MODULEF library structure
When being confronted with a large library such as MODULEF, it is very useful to be able to answer questions such as:
and so forth. To answer all these queries a network type data base has been developed to aid the user.
A "procedure data base" can be consulted interactively to provide information concerning the program hierarchy. For example, information concerning all the routines called by a calling (or main) program can be accessed: called programs calling program. Furthermore, a table of procedures (see section 4.5, part iii) specifies all the libraries to reference when calling a preprocessor. To obtain this information it is necessary to
Program PROIMP utilizes the datafile created by program PROCAT.
An example of the interrogation of the procedure data base is given below. A menu appears as soon as program PROIMP is executed. Say, for example, we would like to know the names of all the subroutines called by subroutine APNOXX. We then choose option PA from the menu, select the > option, and enter the name of the subroutine. We follow the same procedure to extract all the subroutines called by subroutine APNOPW. To return to the main menu, press on the "return" key.
B$ proimp
 **** COMMAND    ( OR ? = HELP ) ?
 BB   : RELATIONS LIBRARIES <--> LIBRARIES
 F    : END (SAME AS Q)
 G    : GENERAL
 LC   : LENGTH OF A COMMON
 NB   : NAMES OF LIBRARIES
 NC   : NAMES OF COMMONS
 NP   : NAMES OF PROCEDURES
 PA   : RELATIONS PROCEDURES <--> CALLED PROCEDURES
 PB   : RELATIONS PROCEDURES <--> LIBRARIES
 PC   : RELATIONS PROCEDURES <--> COMMONS
 P*   : CLOSURE OF CALLED PROCEDURES
 Q    : QUIT THE PROGRAMM (SAME AS F)
PA
 CHOOSE THE RELATIONSHIP :
    >          PROCEDURE > CALLS
    <               CALL < PROCEDURES
    (RETURN)   QUIT
 PROCEDURE ?   (OU *=LISTE COMPLETE, RETURN=QUITTER)
APNOXX
 > CALLS
 APNOPW   FFRONT   INITIS
 NUMBER OF ENTRIES IN THE ABOVE TABLE :       3
APNOPW
 > CALLS
 APNOPO   CNVAPN   IINFO    LECTEU   LIBCAR   LIBCOM   OUVRIR   TITRE
 TRUNIT
 NUMBER OF ENTRIES IN THE ABOVE TABLE :       9
    >          PROCEDURE > CALLS
    <               CALL < PROCEDURES
    (RETURN)   QUIT
 F    : END (SAME AS Q)
 G    : GENERAL
If you would like to terminate the interrogation, simply type the letter Q. Let us however first check which libraries does subroutine COMAXX access. To do this choose option P from the main menu, select option B and type the name of the subroutine:
P*
 SELECTED OPTION :
    A          TREE OF PROCEDURES
    B          TABLE OF LIBRARIES
    P          TABLE OF PROCEDURES
    BP         TABLE OF LIBRARIES + PROCEDURES
    F          FILE  OF LIBRARIES + PROCEDURES
    (RETURN)   QUIT
B
 PROCEDURE ?   (OU RETURN=QUITTER)
COMAXX
 LIBRARIES :
 CONV     CONW     COSD     ELA2     ELA3     ELAS     ELCP     FLUI
 MAGN     PPAL     THER     UTII     U_SUN UTSD     ZZZZ_MOD
 NUMBER OF ENTRIES IN THE ABOVE TABLE :      15
 SELECTED OPTION :
    (RETURN)   QUIT
 F    : END (SAME AS Q)
 G    : GENERAL
Q
 NUMBER OF WORDS USED :        49236 /     5000000
