Modulefpreviousupnextcontents[BIG][Normal][small]
Next: F List of graphic peripherals available Up: Part IV: Appendices Prev: D.2 Possible problems Contents
E Link library list
In order that the editor considers each library only once during the resolution of the external references when performing the linking process, the list of MODULEF libraries must be given in the following order:
batc
bihm
plma
conw
comp
menw
cont
conv
elnl
evol
trac
cosd
visu
bout
flui
calc
elas
reso
elcp
emc2
menu
nop2
nop3
piez
resd
resr
ther
ela2
ela3
magn
nopo
poba
resb
vis3
resc
symo
bnf3
lang
aloc
lisp
utsd
ft3d
p_lMM
< List of graphic peripherals >
p_genera
ft3d
u_MM
zzzz_mod
utii
blas_mod
u_MM
Note: The variable MM represents the name of your machine in the above listing.
