![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
Next: 2 The MODULEF library
Up: 1 The club
Prev: 1.3 Reasons for the creation of
Contents
The main objectives of the MODULEF club are:
- to develop a finite element library using the latest results of theoretical and numerical research in
functional and numerical analysis, as well as industrial experience in the solution of large concrete problems,
- to assemble organizations interested in the same subject in order to join efforts in obtaining an optimal
methodology with the view of programming it,
- to promote the exchange and sharing of knowledge between the members,
- to validate new methods by integrating and comparing them with those which are already implemented, and
- to promote the use of MODULEF.
The realization of the above objectives requires the adoption of the following standards:
- Standardization of programs:
The MODULEF library of programs is written in Fortran 77. A comprehensive documentation of the programming
standards is given in
[4][MODULEF User Guide - 2].
- Portability of programs:
The MODULEF library has been implemented and tested successfully on various Fortran 77 compilers and
operating systems, for example, HP/Apollo, CDC, Cray, IBM, Vax, Sun, etc.
The installation procedures are given in detail in Part III of this user guide.
- Development of computer tools in order to create a coherent, easy-to-use, multi-computer suite of programs.
- Documentation and instruction:
In order to ensure readability of the code, understanding of the underlying algorithms and numerical
methods, as well as making the software geared to research,
documentation is available at different levels:
- A MODULEF handbook summarizes the main aspects of the MODULEF library and introduces
the reader to the ways of using the library (this book serves as a guide at the general five-day teaching
course organized periodically by INRIA).
- A set of MODULEF User Guides are available giving a full documentation of the entire library, including
installation procedure and programming norms. A set of documentation is distributed to all new members along with
the system tape. This documentation is updated each year.
- Documentation is also available in the source code which is accessible by all users. Each module starts
with a short summary of the purpose, parameters, input and output data, and name of author. This summary
can be extracted by a special processor.
- On-line documentation gives a short description of the important or more difficult steps. This is
particularly useful for students.
- Lastly, a processor is available which generates information regarding the routines called by a given routine,
the common storage used, the libraries required and other information regarding the structure of the
software, automatically.
- Organization of work groups:
Seminars and practical work groups are regularly organized at INRIA.
- Maintenance of the MODULEF library:
The system tape is distributed annually to all members of the MODULEF club. It contains the source code of
all the routines, benchmarks and documentation. Special tools are available to split the source code stored
on the tape into source and object libraries automatically.
The code and corresponding documentation, the MODULEF User Guide, is updated annually and
distributed, along with the contributions from members, to all members of the club.
Up: 1 The club
Contents
