Modulefpreviousupnextcontents[BIG][Normal][small]
Next: 3.1 Test 4: Thermal Problem Up: Part II: How do I use Prev: 2.4 Test 3: Plate problem Contents
3 Batch tests
Each test consists of an assembly of principal programs which execute the steps necessary in order to solve the problem under consideration, and a file containing the data necessary in order to create the mesh. The programs are stored in library TEST. The names designated to these programs is of the form DnZZXX.F where:
D
is a letter common to all these programs,
n
is the test number,
ZZ
are two letters representing the step being performed,
XX
is the normal ending of the principal MODULEF programs, and
F
designates a FORTRAN program.
For example, the program
D5CAXX
calculates the element matrices and introduces the boundary conditions for test 5, and the file
D4REXX
calculates the element matrices and introduces the boundary conditions and solves test 4.
