Modulefpreviousupnextcontents[BIG][Normal][small]
Next: B.3 Program type 2 Up: B List of preprocessors Prev: B.1 Introduction Contents
B.2 Program type 1
Type 1 processors require little data. they are activated in the following manner:
  1. start execution;
  2. enter the data (via a set of questions-responses);
  3. direct execution of the module.
The example IMAGXX, which activates the plotting module that requires the contents of a D.S., is an example of a preprocessor of type 1 seen previously.
