Next: B.6 The general preprocessor TOUTXX
Up: B List of preprocessors
Prev: B.4 List of processors (by theme)
Contents
The list below displays all the processors in the MODULEF library. For each
processor, we indicate:
- the name;
- the type of problem to be treated;
- the module(s) it calls (between brackets);
- the data structure(s) it manipulates (between brackets);
- a short description of its function.
List :
- AAPB : Multics - Print the arrays present in the super-array M.
- ADPNXX : Mesh - ( ADPNOP ) [ NOPO ] Add non-vertex nodes.
- AFFNXX : Mesh - ( AFFNOP ) [ NOPO ] Local refinement in 2 dimensions.
- AIDEXX : Aid - Name of the processors and corresponding brochures.
- AIGUXX : Mesh - ( AIGUNO ) [ NOPO ] Make a 2D triangular mesh non-obtuse.
- APN3XX : Mesh - ( APNOP3 ) [ NOPO ] General preprocessor for the creation of 3D meshes
for simple cases, and for their manipulation.
- APNOXX : Mesh - ( APNOPO ) [ NOPO ] General preprocessor for the creation of 2D meshes
and their manipulation.
- ASSAXX : Assembly - ( ASSATR ) [ ATRI B ] Assembly in form ATRI.
- ASSGXX : Assembly - ( ASMAGC ) [ AMAT B ] Assembly in form AMAT.
- ASSMXX : Assembly - ( ASMAPC ) [ MUA B ] Assembly in form MUA.
- BDISXX : Utility - ( BDISEQ ) [ B ] Change a D.S. B in direct access into
a D.S. B in sequential access or vice versa.
- BSPLXX : Utility - ( BSPLIN ) [ NOPO COOR ] Approximation of functions by B-splines.
- CACOXX : Composites - Calculate the mechanical characteristics of an equivalent homogenized
material.
- CHARXX : Mesh - ( CHARPO CHARPL ) [ NOPO ] Define a link between 2 beams or 2 plates.
- CHOLXX : Solution - ( PREPAC ... DRCHPC ) [ TAE MAIL BDCL B ] Cholesky method:
from assembly to solution.
- CHORXX : Solution - ( CLIMPC ... DRCHPC ) [ MUA BDCL B ] Cholesky method:
from boundary conditions to solution.
- CHOSXX : Solution - ( PREPAC ... DRCHPS ) [ TAE MAIL BDCL B ] Cholesky method:
from assembly to solution with direct access.
- COBDXX : Utility - ( COBDC1 ) [ BDCL ] Description of imposed boundary conditions.
- COBVXX : Utility - ( COBVVP ) [ VVPR B ] Store one or several eigen vectors in
a D.S. B.
- CODEXX : Utility - ( CODEVA ) [ VVPR ] Create a file to plot the
eigen values (via TRACXX).
- COLIXX : Mesh - ( COLIBR) [ NOPO ] Construct a 3D mesh from blocks.
- COMAXX : Interpolation - ( COMACO ) [ MAIL COOR ] Define interpolation.
- COMPXX : Mesh - ( COMPRE ) [ NOPO ] Compression of a D.S. NOPO so that nodes and
points coincide.
- CORNXX : Utility - ( CORNOE ) [ MAIL COOR ] Create the D.S. COOR of nodes.
- COSDXX : Utility - ( COSDB COSNOB COSMCB ) [ NOPO MAIL COOR B ] Create a D.S. B
using vectors or coordinates contained in a D.S. NOPO, a D.S. COOR and the
corresponding D.S. MAIL.
- COTAXX : Utility - ( COTABM ) [ NOPO MAIL COOR TABM ] Construction of D.S. TABM -
Navier-Stokes fluid problems.
- COUPXX : Plot - ( TRISO3 ) [ NOPO B ] Isovalues on a slice through a 3D problem.
- CROUXX : Solution - ( PREPAC ... DRCRPC ) [ TAE MAIL BDCL B ] Crout method:
- CSNTXX : Utility - ( CSNTAE ) [ TAE ] Change a symmetric D.S. TAE into
a non-symmetric D.S. TAE.
- CTYTXX : Utility - ( CTYTAE ) [ TAE ] Change a single precision D.S. TAE into
a double precision D.S. TAE or vice versa.
- DEFIXX : Utility - Generate the FORTRAN subroutine to define an element.
- DEFNXX : Mesh - ( DEFNOP ) [ NOPO B ] Create a D.S. NOPO by adding displacements.
- DGRAXX : Solution - ( PREPGC ... CONDLU DGRADA ) [ TAE AMAT MAIL BDCL B ]
Accelerated double conjugate gradient
iterations for non symmetric matrix (positive definite).
- DTRIXX : Mesh - ( DTRI3D ) [ NOPO ] Split the elements of a 3D mesh into tetrahedra.
- ELAPXX : Plasticity - ( ELAPLA ) Calculate the plastic zones.
- ELIMXX : Mesh - ( ELIMNO ) [ NOPO ] Remove one or several elements from a D.S. NOPO.
- ELNLXX : Non-linear elasticity - ( PRELA3 GDEFIN ) [ NOPO MAIL COOR BDCL B ] Solve
an elasticity problem with large deformations.
- EMC˛
: Mesh - ( ) [ NOPO ] Interactive 2D mesh generator and editor.
- EVO2XX : Parabolic - ( EVOLMP ) [ MUA BDCL B ] solve a constant coefficient
first or second order transient problem (multi-step method).
- EVOLXX : Parabolic - ( EVOLGE ) [ MUA BDCL B ] solve a constant coefficient first order
transient problem (Gear's method).
- FLUXXX : Utility - ( FLUXTH ) [ TAE B ] Calculate flux or temperatures for mixed elements.
- FOINXX : Solution - ( FOINRE ) [ MAIL TAE B ] Calculate interface and reaction forces.
- FOMIXX : Utility - ( COMILI COFORC ) [ MILI FORC ] Create the D.S. MILI and FORC
containing the material and force descriptions.
- FRONXX : Solution - ( PREPAF .. FRONT ) [ TAE MAIL BDCL B ] Frontal method : Solution.
- GAUSXX : Solution - ( PREPGC ... GAUSPC DRGAPC ) [ TAE AMAT MAIL BDCL B ]
Gauss method.
- GEODXX : Mesh - ( GEODET ) [ NOPO ] Check a mesh by calculating the areas and volumes of its elements.
- GEONXX : Mesh - ( GEONOP ) [ NOPO GEOM ] Transform a D.S. GEOM into a D.S. NOPO.
- GIBBXX : Mesh - ( GIBBS ) [ NOPO ] Renumber the nodes and elements of a mesh.
- GRADXX : Solution - ( PREPGC ... ) [ TAE MAIL BDCL B ] Conjugate gradient method :
from assembly to solution by conjugate gradient method with or without preconditioning.
- HELPXX : Help - Guide for the solution of non-linear problems (see ELNLXX).
- HOOKXX : Utility - ( INVERD ) Calculate elasticity coefficients from the behavior modules
( Young , Poisson ).
- IMAGXX : Utility - ( IMB .. IMVVPR ) [ B ... VVPR ] Print the contents of a D.S.
- IMATXX : Utility - ( IMATAB ) Print an array contained in the super-array M.
- IMBCXX : Utility - Shells - [ B ] print a D.S. B in the global axis.
- IMNOXX : Utility - ( IMNOPS ) [ NOPO ] Print certain values of a D.S. NOPO.
- IMPOXX : POBA - Print file POBA containing the basis polynomials.
- IMPVXX : The same as IMPOXX - old version.
- INFOXX : Utility - ( INFOB .. ) [ B ... ] Print certain values contained in a D.S.
- INTEXX : Utility - ( INTERF ) [ NOPO ] Imperfect interfaces.
- INVEXX : Utility - ( INVERD ) Inverse a full small matrix, symmetric or not.
- ISOPXX : Plot - ( ISOPIE ) Calculate and plot the pressure level-lines.
- MAXDXX : Utility - ( MAXDLB ) [ B ] Print the extrema of the solutions.
- MA23XX : Mesh - ( MA2D3D ) [ NOPO ] Construct a 3D mesh by stacking 2D meshes.
- MA2DXX : Mesh - ( MA2D3D ) [ NOPO ] Construct a 3D mesh by stacking 2D meshes,
simplified version (corresponding to module MA2D3D of the previous versions).
- MOD1XX : Mesh - ( MODNO1 ) [ NOPO ] Modify values of a D.S. NOPO manually..
- MODMXX : Mesh - ( MODMAI ) [ MAIL COOR ] Modify a mesh by geometric transformations.
- MODNXX : Mesh - ( MODNOP ) [ NOPO ] Modify a mesh by geometric transformations.
- NOFOXX : Utility - ( NOFOSD ) Format or unformat a D.S.
- NOPGXX : Mesh - ( NOPGEO ) [ NOPO GEOM ] Transform a D.S. NOPO into a D.S. GEOM.
- NORMXX : Utility - ( NORME ) [ MAIL COOR TAE B ] Compare a calculated solution with an exact
solution.
- NSKIXX : Solution - ( NSKINC ) [ TABM B B ] Solution of a 2D Navier-Stokes problem.
- NUMMXX : Utility - ( NUMMIX ) Renumber to avoid searching for pivots.
- POBAXX : POBA - ( POBA ) Create the file POBA containing the basis polynomials.
- POBVXX : As above - old version (coupled with THEVXX).
- PROCAT : Procedures - Creation of the procedure base (graph of the subroutines,
libraries, commons, etc.).
- PROIMP : Procedures - Print information contained in the procedure base.
- PRSDOM : Sub-domains - Construction of the operators to solve a problem by a domain decomposition method.
- REC2XX : Mesh - ( RECOLC ) [ NOPO ] The same as RECOXX with 2 arrays M.
- RECOXX : Mesh - ( RECOLC ) [ NOPO ] "Glue together" two meshes.
- REFEXX : Plot - ( REFEGE ) [ NOPO ] Plot 3D meshes, cuts, verification, number modifications
and geometric modifications.
- REFNXX : Mesh - ( REFNOP ) [ NOPO ] Find the referenced faces and sides in a mesh.
- REFPXX : Mesh - ( REFPOI ) [ NOPO ] Find the referenced points in a mesh.
- REHPXX : Utility - ( REHP12 ) [ TAE B ] Calculate displacements for the element
TRIA HP12 ( 2D mixed ).
- REMTXX : Utility - Calculate temperatures for the mixed element.
- RETRXX : Mesh - ( RETRIN ) [ NOPO ] Split elements of a mesh into sub-elements of the same type.
- SDOMVD : Sub-domains - Solve a thermal problem by a sub-domain method (D.P. version).
- SDOMVR : Sub-domains - As above in S.P.
- STREXX : Stresses - ( STRESS ) [ TAE MAIL B ] Calculate the stresses by calculating the
displacements.
- SYMBXX : Utility - ( SYMBEL ) [ NOPO B ] Symmetrize a mesh and the corresponding solution.
- SYFXXX : Eigenvectors - sub-domains at fixed interfaces.
- SYMAXX : Matrix assembly - sub-domains.
- SYPRXX : Preparation - sub-domains.
- SYPSXX : Coupling eigenvectors - sub-domains.
- SYREXX : Results of the modal synthesis [ B ] - sub-domains.
- TESTXX : Utility - A complete simplified sequence to test a single finite element.
- THECXX : Calculus - ( THELCT ELASCT ) [ MAIL COOR TAE ] Calculate the element matrices and RHS vectors
for a constant coefficient problem (elasticity or thermal).
- THELXX : Calculus - ( THELAS ) [ MAIL COOR MILI FORC TAE ] Calculate the element matrices and RHS
vectors for a problem with arbitrary coefficients (elasticity or thermal).
- THEVXX : Calculus - old version.
- TN2DXX : Mesh - ( TN2D3D ) [ NOPO ] Create a surface from a 2D mesh.
- TOUTXX : Utility - General preprocessor: to call particular processors.
- TRACXX : Plot - ( TRAKOU ) Plot curves: Y= F(X) .
- TRCOXX : Mesh - ( TRCOAC ) [ NOPO ] Extract referenced items.
- TRC3XX : Plot - ( TRMC3G ) [ MAIL COOR B ] Plot 3D meshes and solutions
( isovalues, velocities, cuts, deformations, etc.).
- TRMCXX : Plot - ( TRMACO ) [ MAIL COOR B ] Plot 2D meshes and solutions
- TRNOXX : Plot - ( TRNOPO TRGEOM ) [ NOPO GEOM B ] Plot meshes and deformations.
- TRPOXX : plot - ( TRPOIN ) [ DATA of APNOPO ] Plot characteristic points contained in the command
file of APNOPO.
- TRPRXX : Plot - ( TRAKOU ) [ AMAT MUA ] Plot a matrix skyline.
- TRSTXX : Plot - ( TRSTRE TRFLUX ) [ TAE MAIL COOR ] Plot stresses in 2D.
- UNIOXX : Utility - ( UNIONB ) [ B ] Concatenate two D.S. B.
- VALPXX : Eigenvalues and vectors - ( LANCZO ... ) [ MUA ATRI BDCL VVPR ] Compute the eigenvalues
and corresponding vectors.
- VICOXX : Composites - calculate and plot the micro-constraints inherent in a composite material.
- VIS3XX : Plot - Plot surfaces: Z=F(X,Y).
- VISU
: Plot.
- VVDSXX : Utility - ( VVPRDR ) [ VVPR ] Change the type of a D.S. VVPR to create one in
single precision.
- WRNOXX : Formatted output of a D.S. NOPO using the files containing the coordinate and
volumetric data.
Contents
