Next: 5.3 Obtaining general information
Up: 5 Diverse utilities
Prev: 5.1 Initializing a MODULEF program
Index
Contents
It is sometimes convenient to use "Hollerith variables" [Laug 1984]. Such variables are of type INTEGER, but contain 4 characters. The utilities CHAR4 and ICHAR4, described in this section, are used to manipulate them. For example:
INTEGER I, ICHAR4CHARACTER*4 C, CHAR4
I = ICHAR4('ABCD')
WRITE (*, '(A4)') I ABCD
C = CHAR4(I)
WRITE (*, '(A4)') C ABCD
The utility NUMALP is presented later on.
CHARACTER*4 FUNCTION CHAR4( )INTEGER I
This utility effects the conversion: Hollerith CHARACTER*4
INTEGER FUNCTION ICHAR4( )CHARACTER*(*) C
Parameter C is copied into a intermediary variable of type CHARACTER*4, which is truncated or filled by blanks if necessary. Next, this utility effects the conversion: CHARACTER*4 Hollerith.
CHARACTER*1 FUNCTION NUMALP( )INTEGER NB
This utility returns a character for an integer, NB, according to the following conventions:
-1 | returns | '%'. |
0 ... 9 | returns | '0' ... '9'. |
10 ... 35 | returns | 'A' ... 'Z'. |
Any other value | returns | '*'. |
It thus enables us to generate the names of the dynamic arrays belonging to a DS.
