Modulefpreviousupnextcontentsindex[BIG][Normal][small]
Next: 1.7 DS GEOM Up: 1 Description of DS by type Prev: 1.5 DS COOR Index Contents
1.6 DS FORC
1.6.1 Contents
This DS stores information describing the manner in which the data corresponding to the computation of the RHS will be input to the appropriate module (for example module THELAS).
The RHS can be computed using:
The data consists therefore of, depending on the problem under consideration and on the items of interest (reference numbers or sub-domain numbers):
DS FORC consists of 11 arrays of predefined order.
Array FOR0:
General information.
This integer array contains 32 variables, consisting of a general description of the job (title, date, name), of DS FORC (type, level, ...), and indicates the presence or absence of array FOR1.
1:20 TITRE
the job title in 20 words of 4 characters,
21:22 DATE
the date of creation in 2 words of 4 characters,
23:28 NOMCRE
the creator's name in 6 words of 4 characters,
29 'FORC'
the DS type,
30 NIVEAU
the DS level,
31 ETAT
a reserved parameter,
32 NTACM
the number of supplementary arrays
(they are described in array FOR1).
Array FOR1:
Description of any supplementary arrays.
This integer array exists if NTACM (see FOR0) is non-zero. It contains 22 variables for each array to be described. When describing the data which will be contained in one or several arrays, it is useful to associate them with the DS (other possibilities are permissible, such as associating them with DS MILI (see this DS) or DS TAE (see this DS), or otherwise with all the DS present in memory during the computation of the element matrices).
If array FOR1 exists, it contains sequentially:
Array FOR2:
General description of the data sets.
This integer array contains 9 values.
Array FOR3:
Description for a volumetric treatment by sub-domain number.
This integer array contains 7 values.
1 NDSD
the number of the sub-domain described,
2 IADR
the value 0,
3 NUM
the value 0,
4 IOPT
the treatment option: > 0 for isotropic case, < 0 for anisotropic case,
5 CODE
the treatment code, i.e:
  • 1: by array,
  • 2: by subroutine FORCE, or
  • 3: by a user subroutine.
6 INFO1
the first data item corresponding to the treatment:
  • if CODE = 1: the array name,
  • if CODE = 2: the option in subroutine FORCE, or
  • if CODE = 3: 0
7 INFO2
the second data item corresponding to the treatment:
  • if CODE = 1: the address in the array containing the first value to be used,
  • if CODE = 2: the return address in the array of subroutine FORCE of the first value to be used, or
  • if CODE = 3: 0
Arrays FOR4 to FORA have the same form.
Array FOR4:
Description for a surface treatment by reference numbers.
Same as array FOR3, where here:
1 NREF
the reference number described,
2:7
identical to FOR3.
Array FOR5:
Description for a linear treatment by reference numbers.
1 NREF
2:7
identical to FOR3.
Array FOR6:
Description for a point treatment by reference numbers.
1 NREF
2:7
identical to FOR3.
Array FOR7:
Description for a volumetric treatment by element.
1 NREF
the element number described,
2 IADR
the address in array MAIL of DS MAIL of the element,
3:7
identical to FOR3.
Array FOR8:
Description for a surface treatment by element.
1 NREF
2 IADR
its address in MAIL,
3 NUM
the number of the face under consideration,
4:7
identical to FOR3.
Array FOR9:
Description for a linear treatment by element.
1 NREF
2 IADR
3 NUM
the number of the edge under consideration,
4:7
identical to FOR3.
Array FORA:
Description for a point treatment by element.
1 NREF
2 IADR
3 NUM
the number of the vertex under consideration,
4:7
identical to FOR3.
1.6.2 Corresponding tools
Reading and writing a DS FORC
A DS residing in main memory is written completely (it is a category 1 DS) on sequential file via module SDECRI.
Similarly, it is read and restored completely into main memory via SDLECT.
Printing a DS FORC
The contents (total or partial) of a DS FORC can be printed by module IMFORC. Preprocessor IMAGXX is used if a conversational call of IMFORC is desired.
Creation and modification modules for a DS FORC
DS FORC is constructed via module COFORC which can be called by preprocessor FOMIXX.
