Modulefpreviousupnextcontentsindex[BIG][Normal][small]
Next: Part IV: Appendices Up: 1 Description of DS by type Prev: 1.15 DS TYNO Index Contents
1.16 DS VVPR
1.16.1 Contents
This DS stores information corresponding to the eigenvalues and vectors of a system.
DS VVPR is composed of five arrays of predefined order.
Array VVP0:
General information.
This integer array contains 32 variables, consisting of a general description of the job (title, date, name), of DS VVPR (type, level, ...), and indicates the presence or absence of array VVP1.
1:20 TITRE
the job title in 20 words of 4 characters,
21:22 DATE
the data of creation in 2 words of 4 characters,
23:28 NOMCRE
the creator's name in 6 words of 4 characters,
29 'VVPR'
the DS type,
30 NIVEAU
the DS level,
31 ETAT
a reserved parameter,
32 NTACM
the number of supplementary arrays associated with the DS (they are described in array VVP1).
Array VVP1:
Description of any supplementary arrays.
This array is analogous to array B1 of DS B (see this DS).
Array VVP2:
General description.
This integer array contains 7 values.
1 NTYVA
the type of eigenvalues,
2 NVALPR
the number of eigenvalues,
3 NTYVE
the type of eigenvectors,
4 NCVEC
the number of eigenvector components,
5 NEBER
the existence (1) or not (0) of an error bound for the eigenvalues,
6 NGT
the number of couples in array VVP3, VVP4 on file,
7 NEXVEC
0 if there are no eigenvectors, 1 otherwise.
Array VVP3:
The eigenvalues.
This NTYVA type array contains:
Array VVP4:
The eigenvectors.
This NTYVE type array, which exists if NEXVEC equals 1, contains:
1.16.2 Corresponding tools
Reading and writing a DS VVPR
A DS residing in core is written partially (it is a category 2 DS); only its 3 generic arrays and any associated arrays described in array VVP1 are written to sequential file via module SDECRI.
Similarly, a DS residing on file is read and transferred partially (its 3 generic arrays and any associated arrays described in array VVP1) to main memory via module SDLECT; only arrays VVP3 and VVP4 are addressed:
Printing a DS VVPR
The contents (total or partial) of a DS VVPR can be printed by module IMVVPR. Preprocessor IMAGXX is used when a conversational call of IMVVPR is desired.
Creation and modification modules for a DS VVPR
DS VVPR is created using different modules corresponding to different methods (Lanczos, sub-space, etc.).
