Next: Contents
Up: Guide 3 Mesh Construction and Modification
Prev: Guide 3 Mesh Construction and Modification
Index
Contents
This preprocessor calls all the modules creating or modifying a 2D mesh via a system of keywords. The modules are described in chapter 4, where they are arranged in an alphabetic order.
The latter calls all the modules manipulating 3D meshes and certain modules for creating these meshes (only modules that require minimal data).
Chapter 3 presents the modules corresponding to the three possible methods of generating meshes, when dealing with more complex geometries.
This set of programs are described in chapter 4.
