Modulefpreviousupnextcontentsindex[BIG][Normal][small]
Next: 1.4 The module APNOPO Up: 1.3 Main ideas Prev: 1.3.3 Modification of the numbers Index Contents
1.3.4 Definition of the nodes
Generally speaking, modules responsible for the creation and modification of meshes only consider geometrical meshes (i.e. nodes=vertices). For certain finite elements, the nodes may differ from the vertices. Consequently, once the geometric mesh is completed, the non-vertex nodes can be introduced. For example:
Module ADPNOP (keyword ADPO) performs this prescription.
