Next: 2.3.2 Modification of the numbers
Up: 2.3 Main ideas
Prev: 2.3 Main ideas
Index
Contents
This structure contains the following information (see chapter 1):
The MODULEF code stores this information in a NOPO type data structure, constituting the natural interface between the different mesh modules.
Remark:
As many reference numbers are assigned as required in order to incorporate the entire set of descriptions.
