Modulefpreviousupnextcontentsindex[BIG][Normal][small]
Next: 3.2.4 Module COLIBR Up: 3.2 Multi-block method Prev: 3.2.2 Calling of module COLIB2 Index Contents
3.2.3 Calling of the derived modules
The derived modules are constructed using COLIB2 for the case where there is only one single block of a given type. There are consequently 3 derived modules: COLIBT , COLIBP  and COLIBH  corresponding to the case of a single tetrahedron, pentahedron or hexahedron.
The data is of the same type as above, but is simpler to enter because some data is implicitly known.
There are two options to assign reference numbers: the one indicates that all these numbers will be set to 0, and the other allows a distinct number to be assigned to each item created.
COLIBT: tetrahedral case
Remark:
COLIBP: pentahedral case
Remark:
COLIBH: hexahedral case
Remark:
