Next: 3.4 Method for a hexahedral topology
Up: 3.3 Extrusion method (cylindrical topology)
Prev: 3.3.5 The preprocessor MA23XX
Index
Contents
Some examples of calling module MA2D3E in batch and calls via preprocessor MA23XX are given below.
First, an example with TTYPE = -1, and the same with TTYPE = - 2 , i.e., a step-by-step definition of the section starting from the basis via the general matrix, MAT, or via function XYZ23.
The calling programs, the output obtained during execution of case 1, and a plot of the resulting mesh (figure 3.14) is shown below.
Definition via MAT (TTYPE = -1):
C +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
C EXAMPLE OF CALLING MODULE MA2D3E : TEST WITH A MATRIX
PARAMETER (LM = 100000 , MAXFON = 4 , MAXSEC = 9 , MAXDES = 10 )
COMMON M(LM)
INTEGER NUCOU(3,MAXFON),DESREF(5,MAXDES)
REAL MAT(4,4,MAXFON)
REAL ZINT(0:MAXSEC)
LOGICAL BFONC,COLLER,RAPIDE
EXTERNAL XYZ23,XYZ33
C
IMPRE = 5
CALL INITIS(M,LM,IMPRE,0)
C ------ THE I.D.S. NOPO AND THE O.D.S. NOPO
NFNOPO = 10
NINOPO = 1
CALL OUVRIR(NFNOPO,'nopo2d.ma23.2',
+ 'OLD,UNFORMATTED',0,IOSTAT)
NFNOPS = 11
NINOPS = 2
CALL OUVRIR(NFNOPS,'nopo3d.ma23.1','UNFORMATTED',0,IOSTAT)
C -----------------------------------------------
C ------ GEOMETRIC TRANSFORMATIONS ------
C --- THE BASIS:
BFONC = .FALSE.
ZINT(0) = -1.
NBCOU = 4
C --- MATRICES BETWEEN
C THE BASIS AND THE ONE ABOVE DEFINED BY MAT
C TO CONSTRUCT SECTIONS 1 TO 4
NBFONC = 4
DO ISEC=1,4
NUCOU(1,ISEC) = ISEC - 1
NUCOU(2,ISEC) = ISEC
NUCOU(3,ISEC) = -1
ENDDO
C
DO ISEC=1,4
MAT(1,1,ISEC) = 0.8
MAT(1,2,ISEC) = 0.
MAT(1,3,ISEC) = 0.
MAT(1,4,ISEC) = 0.
MAT(2,1,ISEC) = 0.
MAT(2,2,ISEC) = 0.8
MAT(2,3,ISEC) = 0.
MAT(2,4,ISEC) = 0.
MAT(3,1,ISEC) = 0.
MAT(3,2,ISEC) = 0.
MAT(3,3,ISEC) = 1.
MAT(3,4,ISEC) = 1. + ISEC
MAT(4,1,ISEC) = 0.
MAT(4,2,ISEC) = 0.
MAT(4,3,ISEC) = 0.
MAT(4,4,ISEC) = 1.
ENDDO
C ------ DEFINITION OF THE REFERENCES ------
NBDES = 2
C --- BASIS: FACES EDGE AND POINTS SET TO REFERENCE 1 :
IDES = 1
DESREF(1,IDES) = 0
DESREF(2,IDES) = 0
DESREF(3,IDES) = 0
DESREF(4,IDES) = -100
DESREF(5,IDES) = 1
C ---
C --- ABOVE: FACES EDGES AND POINTS SET TO REFERENCE 2 :
IDES = 2
DESREF(1,IDES) = 9
DESREF(2,IDES) = 9
DESREF(3,IDES) = 0
DESREF(5,IDES) = 2
C ------ CALL THE MODULE ------
EPS = 0.001
COLLER = .FALSE.
RAPIDE = .TRUE.
C
CALL MA2D3E(M,M,NFNOPO,NINOPO,NFNOPS,NINOPS,NBCOU,EPS,NBFONC,
+ NUCOU,MAT,COLLER,RAPIDE,DESREF,NBDES,ZINT,BFONC,
+ XYZ23,XYZ33)
END
Figure 3.14: Example MA2D3E (step-by-step definition via MAT or XYZ23)
M M OOO DDDD U U L EEEEE FFFFF
MM MM O O D D U U L E F
M M M O O D D U U L EEEE FFFF
M M O O D D U U L E F
M M OOO DDDD UUU LLLLL EEEEE F VERSION 91
DATE : 16/10/91
AUTHOR : dutoit
++ OPEN(10,FILE='nopo2d.ma23.2',SPEC='OLD,UNFORMATTED',RECL=0)
++ OPEN(11,FILE='nopo3d.ma23.1',SPEC='UNFORMATTED',RECL=0)
MODULE MA2D3E :
HEIGHT OF THE BOTTOM BASIS : -0.1000000E+01
NUMBER OF GEOMETRIC TRANSFORMATIONS : 4
LIST OF TRANSFORMATIONS :
SECTION 0 A 1 TYPE OF TRANSFORMATION -1
SECTION 1 A 2 TYPE OF TRANSFORMATION -1
SECTION 2 A 3 TYPE OF TRANSFORMATION -1
SECTION 3 A 4 TYPE OF TRANSFORMATION -1
NUMBER OF TRANSFERS OF NUMBERS : 2
LIST OF TRANSFERS :
SECTION 0 A 0 TYPE OF TRANSFER 0 : -100 GIVES 1
SECTION 9 A 9 TYPE OF TRANSFER 0 : -100 GIVES 2
MESH OBTAINED : SAVE D.S.
TABLE N O P 2
MESH CHARACTERISTICS :
SPACE DIMENSION (NDIM ) : 3
MAXIMUM NUMBER OF REFERENCES (NDSR ) : 1
MAXIMUM NUMBER OF SUB-DOMAINS (NDSD ) : 1
NODES AND POINTS COINCIDE (NCOPNP) : 1
NUMBER OF ELEMENTS (NE ) : 880
NUMBER OF PENTAHEDRA (NPENT) : 880
NUMBER OF BOUNDARY ELEMENTS (NEF ) : 72
NUMBER OF NODES (NOE ) : 710
NUMBER OF NODES PER SEGMENT (NO EXTREMITIES) : 0
TYPE OF COORDINATE VALUES (NTYCOO) : REEL1MOT
MAX DIFFERENCE +1 BETWEEN 2 NODES OF AN ELEMENT : 271
NUMBER OF COARSE ELEMENTS (NBEGM ) : 0
NUMBER OF WORDS IN ARRAY NOP5 (LNOP5 ) : 13420
REFERENCE AXIS X,Y,Z (NTACOO) : 1
END OF MODULE MA2D3E
A definition via XYZ23 (TTYPE = -2):
C EXAMPLE OF CALLING MODULE MA2D3E : TEST WITH XYZ23 THROUGHOUT
COMMON M(LM)
REAL ZINT(0:MAXSEC)
C
IMPRE = 5
C ------ THE I.D.S. NOPO AND THE O.D.S. NOPO ------
NFNOPO = 10
NINOPO = 1
NFNOPS = 11
NINOPS = 2
CALL OUVRIR(NFNOPS,'nopo3d.ma23.2','UNFORMATTED',0,IOSTAT)
C --- THE BASIS :
BFONC = .FALSE.
ZINT(0) = -1.
NBCOU = 4
C --- FUNCTIONS XYZ23
C BETWEEN THE BASE THE ONE ABOVE DEFINED BY XYZ23
NBFONC = 4
DO ISEC=1,4
NUCOU(3,ISEC) = -2
ENDDO
C
NBDES = 2
C --- BASIS : FACES EDGES AND POINTS SET TO REFERENCE 1 :
IDES = 1
DESREF(1,IDES) = 0
DESREF(2,IDES) = 0
DESREF(3,IDES) = 0
DESREF(5,IDES) = 1
C ---
C --- ABOVE : FACES EDGES AND POINTS SET TO REFERENCE 2 :
IDES = 2
DESREF(1,IDES) = 9
DESREF(2,IDES) = 9
DESREF(3,IDES) = 0
DESREF(5,IDES) = 2
EPS = 0.001
COLLER = .FALSE.
RAPIDE = .TRUE.
C
+ XYZ23,XYZ33)
END
C
C SUBROUTINE XYZ23
SUBROUTINE XYZ23(I,NUM,NREF,X,Y,Z,X3,Y3,Z3)
REAL*4 DZ(4)
DATA DZ/ 2., 5. , 9., 14./
C
X3 = 0.8 **I * X
Y3 = 0.8 **I * Y
Z3 = Z + DZ(I)
END
An example with TTYPE = -3 for sections 5 to 9 and TTYPE = -6 for the first sections. Consequently, we have:
The calling program, the output obtained during execution and a plot of the resulting mesh is shown below.
C EXAMPLE OF CALLING MODULE MA2D3E : TEST NUMBER 3
PARAMETER (LM = 100000 , MAXFON = 2 , MAXSEC = 9 , MAXDES = 10 )
COMMON M(LM)
REAL ZINT(0:MAXSEC)
C
IMPRE = 5
C ------ THE I.D.S NOPO AND THE O.D.S NOPO ------
NFNOPO = 10
NINOPO = 1
NFNOPS = 11
NINOPS = 2
CALL OUVRIR(NFNOPS,'nopo3d.ma23.36','UNFORMATTED',0,IOSTAT)
C ------ GEOMETRICAL TRANSFORMATIONS ------
C --- LA BASE :
BFONC = .FALSE.
ZINT(0) = -1.
C --- THE INTERMEDIARY SIDES :
NBCOU = 9
ZINT(1) = 0.
ZINT(2) = 2.
ZINT(3) = 4.
ZINT(4) = 6.
ZINT(5) = 7.
C --- A FUNCTION : A MANUAL INTERPOLATION
C BETWEEN THE BASIS AND THE ONE ABOVE DEFINED BY XYZ23
C FOR SIDE 10. ( SEE XYZ23 )
C TO CONSTRUCT SECTIONS 1 TO 5
NBFONC = 2
C
IFONC = 1
NUCOU(1,IFONC) = 0
NUCOU(2,IFONC) = 5
NUCOU(3,IFONC) = -6
C --- A FUNCTION : LOCAL DEFINITION BY XYZ33
C TO CONSTRUCT SECTIONS 6 TO 9
IFONC = 2
NUCOU(1,IFONC) = 5
NUCOU(2,IFONC) = 9
NUCOU(3,IFONC) = -3
NBDES = 2
IDES = 1
DESREF(1,IDES) = 0
DESREF(2,IDES) = 0
DESREF(3,IDES) = 0
DESREF(5,IDES) = 1
C ---
IDES = 2
DESREF(1,IDES) = 9
DESREF(2,IDES) = 9
DESREF(3,IDES) = 0
DESREF(5,IDES) = 2
EPS = 0.001
COLLER = .FALSE.
RAPIDE = .TRUE.
C
+ XYZ23,XYZ33)
END
C SUBROUTINE XYZ33
SUBROUTINE XYZ33(I,NUM,NREF,X,Y,Z,X3,Y3,Z3)
C
X3 = 0.10 * I * X
Y3 = 0.10 * I * Y
Z3 = Z + 0.450
END
C SUBROUTINE XYZ23
C
X3 = X / 2.5
Y3 = Y / 2.5
Z3 = 10.
END
Figure 3.15: Example MA2D3E (an interpolation followed by step-by-step definitions)
DATE : 16/10/91
AUTHOR : dutoit
MODULE MA2D3E :
SECTION 0 TO 5 TYPE OF TRANSFORMATION -6
SECTION 5 TO 9 TYPE OF TRANSFORMATION -3
LIST OF TRANSFERS :
SECTION 0 TO 0 TYPE OF TRANSFER 0 : -100 GIVES 1
SECTION 9 TO 9 TYPE OF TRANSFER 0 : -100 GIVES 2
TABLE N O P 2
NUMBER OF ELEMENTS (NE ) : 1980
NUMBER OF PENTAHEDRA (NPENT) : 1980
NUMBER OF NODES (NOE ) : 1420
NUMBER OF WORDS IN ARRAY NOP5 (LNOP5 ) : 29040
An example with TTYPE = -4, i.e., starting from the 2D mesh data (a ring with reference 1 for the items of the internal circle and reference 2 for the external circle), we define the basis via ZINT(0) = 10. and construct sections 1 to 4 of the sides given in array ZINT(1:4) by translation.
The references of the 3D mesh are attributed via array DESREF(.,.) (see the calling program for the specification of the transfers and figure 3.16 for the result obtained.
C EXAMPLE OF CALLING MODULE MA2D3E : TEST NUMBER 4
PARAMETER (LM = 100000 , MAXFON = 1 , MAXSEC = 9 , MAXDES = 10 )
COMMON M(LM)
REAL ZINT(0:MAXSEC)
C
IMPRE = 5
NFNOPO = 10
CALL TRUNIT (NFNOPO)
NINOPO = 1
CALL OUVRIR(NFNOPO,'NOPO2D.MA23.1','OLD,UNFORMATTED',0,IOSTAT)
NFNOPS = 11
CALL TRUNIT (NFNOPS)
NINOPS = 2
CALL OUVRIR(NFNOPS,'NOPO3D.MA23.4','UNFORMATTED',0,IOSTAT)
C --- The BASIS :
BFONC = .FALSE.
ZINT(0) = 10.
NBCOU = 4
ZINT(1) = 11.
ZINT(2) = 12.
ZINT(3) = 13.
ZINT(4) = 14.5
C --- A FUNCTION : A MANUAL TRANSLATION
NBFONC = 1
C
IFONC = 1
NUCOU(1,IFONC) = 0
NUCOU(2,IFONC) = 4
NUCOU(3,IFONC) = -4
NBDES = 6
C --- BASIS : FACES EDGES AND POINTS SET TO REFERENCE 3 :
IDES = 1
DESREF(1,IDES) = 0
DESREF(2,IDES) = 0
DESREF(3,IDES) = 0
DESREF(5,IDES) = 3
C ---
C --- ABOVE : FACES EDGES AND POINTS SET TO REFERENCE 4 :
C ABOVE : THEN EDGE 1 (2D) ==> EDGE 7 (3D)
C ABOVE : THEN EDGE 2 (2D) ==> EDGE 8 (3D)
IDES = 2
DESREF(1,IDES) = 4
DESREF(2,IDES) = 4
DESREF(3,IDES) = 0
DESREF(5,IDES) = 4
IDES = 3
DESREF(1,IDES) = 4
DESREF(2,IDES) = 4
DESREF(3,IDES) = 4
DESREF(4,IDES) = 1
DESREF(5,IDES) = 7
IDES = 4
DESREF(1,IDES) = 4
DESREF(2,IDES) = 4
DESREF(3,IDES) = 4
DESREF(4,IDES) = 2
DESREF(5,IDES) = 8
C --- VERTICAL FACES : EDGE 1 (2D) ==> FACE 5 (3D)
C EDGE 2 (2D) ==> FACE 6 (3D)
IDES = 5
DESREF(1,IDES) = 0
DESREF(2,IDES) = 4
DESREF(3,IDES) = 3
DESREF(4,IDES) = 1
DESREF(5,IDES) = 5
IDES = 6
DESREF(1,IDES) = 0
DESREF(2,IDES) = 4
DESREF(3,IDES) = 3
DESREF(4,IDES) = 2
DESREF(5,IDES) = 6
EPS = 0.001
COLLER = .FALSE.
RAPIDE = .TRUE.
C
+ XYZ23,XYZ33)
END
Figure 3.16: Example MA2D3E (translation)
DATE : 16/10/91
AUTHOR : dutoit
++ OPEN(10,FILE='nopo2d.ma23.1',SPEC='OLD,UNFORMATTED',RECL=0)
++ OPEN(11,FILE='nopo3d.ma23.4',SPEC='UNFORMATTED',RECL=0)
MODULE MA2D3E :
HEIGHT OF THE BOTTOM BASIS : 0.1000000E+02
NUMBER OF GEOMETRIC TRANSFORMATIONS : 1
SECTION 0 TO 4 TYPE OF TRANSFORMATION -4
NUMBER OF NUMBER TRANSFERS : 6
LIST OF TRANSFERS :
SECTION 0 TO 0 TYPE OF TRANSFER 0 : -100 GIVES 3
SECTION 4 TO 4 TYPE OF TRANSFER 0 : -100 GIVES 4
SECTION 4 TO 4 TYPE OF TRANSFER 4 : 1 GIVES 7
SECTION 4 TO 4 TYPE OF TRANSFER 4 : 2 GIVES 8
SECTION 0 TO 4 TYPE OF TRANSFER 3 : 1 GIVES 5
SECTION 0 TO 4 TYPE OF TRANSFER 3 : 2 GIVES 6
TABLE N O P 2
MAXIMUM NUMBER OF REFERENCES (NDSR ) : 8
NUMBER OF ELEMENTS IN THE MESH (NE ) : 144
NUMBER OF HEXAHEDRA (NHEX ) : 144
NUMBER OF BOUNDARY ELEMENTS (NEF ) : 28
NUMBER OF NODES (NOE ) : 240
MAX DIFFERENCE +1 BETWEEN 2 NODES OF AN ELEMENT : 78
NUMBER OF WORDS IN ARRAY NOP5 (LNOP5 ) : 4968
An example with TTYPE = -5, i.e., definition of the upper basis (via XYZ23 at side Z=10.) and interpolation between the basis (ZINT(0) = -1.) and this section to construct 5 sections with equidistant sides between that of the basis and that of the upper section.
The references of the 3D mesh are attributed via via array DESREF(.,.) (see the calling program for the specification of the transfers and figure 3.18 for the result obtained).
Extracts of the calling program and a plot of the resulting mesh is shown below.
C EXAMPLE OF CALLING MODULE MA2D3E : TEST NUMBER 5
COMMON M(LM)
REAL ZINT(0:MAXSEC)
C
IMPRE = 5
NFNOPO = 10
NINOPO = 1
NFNOPS = 11
NINOPS = 2
CALL OUVRIR(NFNOPS,'nopo3d.ma23.5','UNFORMATTED',0,IOSTAT)
C --- LA BASE :
BFONC = .FALSE.
ZINT(0) = -1.
NBCOU = 5
NBFONC = 1
C
IFONC = 1
NUCOU(1,IFONC) = 0
NUCOU(2,IFONC) = 5
NUCOU(3,IFONC) = -5
NBDES = 5
IDES = 1
DESREF(1,IDES) = 0
DESREF(2,IDES) = 0
DESREF(3,IDES) = 0
DESREF(5,IDES) = 1
C ---
.... (SEE EXAMPLE BELOW)
EPS = 0.001
COLLER = .FALSE.
RAPIDE = .TRUE.
C
+ XYZ23,XYZ33)
END
C SUBROUTINE XYZ23
C
X3 = X / 2.5
Y3 = Y / 2.5
Z3 = 10.
END
Figure 3.17: Example MA2D3E (interpolation equidistant in z)
An example with TTYPE = -6, i.e., definition of a virtual upper basis (via XYZ23 at side Z=10.) and interpolation between the basis (ZINT(0) = -1.) and this section to construct 5 sections of sides contained in array ZINT(1:5).
The references of the 3D mesh are attributed via array DESREF(.,.) (see the calling program for the specification of the transfers and figure 3.18 for the result obtained).
The calling program, the output obtained during execution and a plot of the mesh obtained is shown below.
C EXAMPLE OF CALLING MODULE MA2D3E : TEST NUMBER 6
COMMON M(LM)
REAL ZINT(0:MAXSEC)
C
IMPRE = 5
NFNOPO = 10
NINOPO = 1
NFNOPS = 11
NINOPS = 2
CALL OUVRIR(NFNOPS,'nopo3d.ma23.6','UNFORMATTED',0,IOSTAT)
C --- LA BASE :
BFONC = .FALSE.
ZINT(0) = -1.
NBCOU = 5
ZINT(1) = 0.
ZINT(2) = 2.
ZINT(3) = 4.
ZINT(4) = 6.
ZINT(5) = 7.
NBFONC = 1
C
IFONC = 1
NUCOU(1,IFONC) = 0
NUCOU(2,IFONC) = 5
NUCOU(3,IFONC) = -6
NBDES = 5
IDES = 1
DESREF(1,IDES) = 0
DESREF(2,IDES) = 0
DESREF(3,IDES) = 0
DESREF(5,IDES) = 1
C ---
C --- ABOVE : FACES EDGES AND SET TO REFERENCE 2 :
C ABOVE : THEN EDGE 1 (2D) ==> EDGE 4 (3D)
IDES = 2
DESREF(1,IDES) = 5
DESREF(2,IDES) = 5
DESREF(3,IDES) = 0
DESREF(5,IDES) = 2
IDES = 3
DESREF(1,IDES) = 5
DESREF(2,IDES) = 5
DESREF(3,IDES) = 4
DESREF(4,IDES) = 1
DESREF(5,IDES) = 4
C --- VERTICAL FACES : EDGE 1 (2D) ==> FACE 2 (3D)
C EDGE 2 (2D) ==> FACE 3 (3D)
IDES = 4
DESREF(1,IDES) = 0
DESREF(2,IDES) = 5
DESREF(3,IDES) = 3
DESREF(4,IDES) = 1
DESREF(5,IDES) = 2
IDES = 5
DESREF(1,IDES) = 0
DESREF(2,IDES) = 5
DESREF(3,IDES) = 3
DESREF(4,IDES) = 2
DESREF(5,IDES) = 3
EPS = 0.001
COLLER = .FALSE.
RAPIDE = .TRUE.
C
+ XYZ23,XYZ33)
END
C SUBROUTINE XYZ23
C
X3 = X / 2.5
Y3 = Y / 2.5
Z3 = 10.
END
Figure 3.18: Example MA2D3E (interpolation)
DATE : 17/10/91
AUTHOR : dutoit
++ OPEN(11,FILE='nopo3d.ma23.6',SPEC='UNFORMATTED',RECL=0)
MODULE MA2D3E :
NUMBER OF NUMBER TRANSFERS : 5
LIST OF TRANSFERS :
SECTION 5 TO 5 TYPE OF TRANSFER 0 : -100 GIVES 2
SECTION 5 TO 5 TYPE OF TRANSFER 4 : 1 GIVES 4
SECTION 0 TO 5 TYPE OF TRANSFER 3 : 1 GIVES 2
SECTION 0 TO 5 TYPE OF TRANSFER 3 : 2 GIVES 3
TABLE N O P 2
MAXIMUM NUMBER OF REFERENCES (NDSR ) : 4
NUMBER OF ELEMENTS IN THE MESH (NE ) : 1100
NUMBER OF PENTAHEDRA (NPENT) : 1100
NUMBER OF NODES (NOE ) : 852
NUMBER OF WORDS IN ARRAY NOP5 (LNOP5 ) : 21500
As an example of a call by MA23XX, or keyword MA23, of APNOP3, we return partly to chapter 2 (translation case) and then to chapter 5 (a complete example is given with explanations), after which we give the 4 following examples (a listing of the data file, a plot of the 2D starting mesh and a plot of the resulting mesh in each case).
An example (figure 3.19) of translation coupled with a rotation:
2 $ IMPRE
engr2d.nopo$ NOMF2D
engr3d.nopo$ NOMF3D
$ === DEFINITION OF THE FUNCTION ===
BASE 0.1000000E+02 $ THE BASIS
TRAN
3 $ TOP SECTION
0.0000000E+00 0.0000000E+00 0.4000000E+00 $ TRANSLATION VECTOR
COMBINE
ROTA
0.2500000E+01 $ ANGLE OF ROTATION
0.0000000E+00 0.0000000E+00 0.0000000E+00 $ A POINT ON THE AXIS
0.0000000E+00 0.0000000E+00 0.1000000E+01 $ ROTATIONAL AXIS
FIN
$ END OF THE FUNCTION DEFINITION
$ =========== THE OPTIONS =========
$ === DESCRIPTION OF THE REFERENCES ===
REF
ARFA 0 3 3 3 $ TYPE : FROM .. TO .. , .. 2D GIVES .. 3D
ARFA 0 3 2 1 $ TYPE : FROM .. TO .. , .. 2D GIVES .. 3D
ARFA 0 3 4 2 $ TYPE : FROM .. TO .. , .. 2D GIVES .. 3D
F
$ END OF THE REFERENCE DESCRIPTION
$ ======= CALLING THE MESH GENERATOR =======
GO
engr2d.psfig:maxx1Starting meshengr3d.psfig:maxx11Result
An example (figure 3.21) of complete rotation coupled with gluing the 2 end sections together.
2 $ IMPRE
piston2d.nopo$ NOMF2D
piston3d.nopo$ NOMF3D
BASE 0.0000000E+00 $ THE BASIS
ROTA
36 $ TOP SECTION
0.1000000E+02 $ ANGLE OF ROTATION
0.0000000E+00 0.1000000E+01 0.0000000E+00 $ ROTATIONAL AXIS
FIN
COLLER
REF
GLOB 0 36 0 0 $ TYPE : FROM .. TO .. , BIDON , BIDON
F
GO
piston2d.psfig:maxx2Starting meshpiston3d.psfig:maxx21Result
An example of translation and rotation with degeneration.
We will note the creation of pentahedra (and not hexahedra) in the degeneration zone (figure 3.23).
2 $ IMPRE
dege2d.nopo$ NOMF2D
dege3d.nopo$ NOMF3D
XYZ23
0 $ TOP SECTION
1 $ VIA FUNCTION PARSER
X01(N,X,Y)=
X;
Y01(N,X,Y)=
Y;
Z01(N,X,Y)=
0.;
FIN
TRAN
5 $ TOP SECTION
0.0000000E+00 0.0000000E+00 0.5000000E+00 $ TRANSLATION VECTOR
ROTA
10 $ TOP SECTION
-0.6000000E+01 $ ANGLE OF ROTATION
0.0000000E+00 0.0000000E+00 0.2500000E+01 $ A POINT ON THE AXIS
0.1000000E+01 0.0000000E+00 0.0000000E+00 $ ROTATIONAL AXIS
TRAN
15 $ TOP SECTION
0.0000000E+00 0.0000000E+00 0.2500000E+00 $ TRANSLATION VECTOR
FIN
VERVOL
REF
FASU 1 $ TYPE : NUMBER ASSIGNED
F
GO
dege2d.psfig:maxx3Starting meshdege3d.psfig:maxx31Result
An example (figure 3.25 and3.26) of rotation of a section consisting of a line, and thereby the construction of a surface mesh .
2 $ IMPRE
verre2d.nopo$ NOMF2D
verre3d.nopo$ NOMF3D
ROTA
36 $ TOP SECTION
-0.1000000E+02 $ ANGLE OF ROTATION
FIN
$END OF THE FUNCTION DEFINITION
COLLER
GO
verre2d.psfig:maxx4-1Starting meshverre3d.psfig:maxx4-2Result
