Modulefpreviousupnextcontentsindex[BIG][Normal][small]
Next: 5.2 A two-dimensional example Up: 5 Tutorial examples Prev: 5 Tutorial examples Index Contents
5.1 Introduction
In order to become acquainted with the mesh construction and modification modules, the reader is referred to the relevant chapters depending on his/her need:
In the present chapter two supplementary examples are given. For each, and for the domain under consideration, the different steps to be followed in the mesh creation process are described in full. We therefore present:
