Modulefpreviousupnextcontentsindex[BIG][Normal][small]
Next: The EMC˛ preprocessor Up: 1.4 The module APNOPO Prev: 1.4.4 A complete example Index Contents
1.4.5 Abbreviated list of the keywords
COUR
Definition of the curves present in the domain via a function parser.
POIN
Definition of the characteristic points.
LIGN
Definition of the characteristic lines from the characteristic points.
QUAC
Call the algebraic mesh generator for a generalized quadrilateral.
TRIC
Call the algebraic mesh generator for a generalized triangle.
TRIA
Call the advancing-front mesh generator for an arbitrary domain.
TRIH
Call the Voronoï mesh generator for an arbitrary domain.
MANU
Call the manual mesh generator.
OBJE
Call the mesh generator for a single element.
BARR
Call the mesh generator to create segments from a contour.
TRAN
Translation of a given mesh.
ROTA
Rotation of a given mesh.
SYMD
Symmetry with respect to a line in a given mesh.
DILA
Dilation of a given mesh.
Q4T
Split each quadrangle of a mesh into four triangles.
RETR
Split each element of a mesh into sub-elements of the same type.
REGU
Regularization of a mesh by barycentering.
AIGU
Remove obtuse angles from a mesh composed of triangles.
AFFL
Refine a mesh locally around certain vertices.
NUME
Modify attributes (reference or sub-domain number) in a mesh.
RECO
"Glue together" two meshes.
ADPO
Definition of nodes in a given mesh.
EXTR
Extraction of the edges with reference numbers given.
RENE
Renumbering of the elements of a mesh.
RENC
Renumbering of the elements and nodes of a mesh.
COUL
Renumbering of the elements by coloring.
SAUV
Store a mesh resident in main memory on file.
INTR
Introduce a mesh resident on file into main memory.
TUER
Delete one or several data structures in memory.
IMPR
Print the contents of a NOPO data structure.
DESS
Plot a mesh.
FIN
End of job.
