Next: 2.4 General presentation of module APNOP3
Up: 2.3 Main ideas
Prev: 2.3.2 Modification of the numbers
Index
Contents
Generally speaking, modules responsible for the creation and modification of meshes only consider geometrical meshes (i.e. nodes=vertices). For certain finite elements, the nodes may differ from the vertices. Consequently, once the geometric mesh is completed, the non-vertex nodes can be introduced. For example:
Module ADPNOP (keyword ADPO) performs this prescription.
