Modulefpreviousupnextcontentsindex[BIG][Normal][small]
Next: 3.2.3 Calling of the derived modules Up: 3.2 Multi-block method Prev: 3.2.1 Quick description of the method Index Contents
3.2.2 Calling of module COLIB2
Preprocessor COLIXX  (see below as well as the simplified versions and module
[4] COLIBR) initiates a conversational call to the module for the case where the amount  of input data is little. In the general case, it seems simpler to call the module directly by writing a main program as follows:
Remarks:
