Modulefpreviousupnextcontentsindex[BIG][Normal][small]
Next: 1.2 Methodology Up: 1 Two-dimensional mesh generation Prev: 1 Two-dimensional mesh generation Index Contents
1.1 Introduction
The MODULEF library proposes the following algorithms for two-dimensional meshes:
Module APNOPO, called directly, or via the preprocessor APNOXX, performs the following functions:
  1. generates two-dimensional meshes from the point, line, contour, etc., data, using the mesh algorithms;
  2. stores the NOPO data structures (or D.S.), containing the meshes created, in main memory;
  3. modifies and combines these meshes to form new meshes, along with their corresponding D.S. NOPO, which can be saved on sequential file.
EMC˛ allows:
