Modulefpreviousupnextcontentsindex[BIG][Normal][small]
Next: 3.2.6 Some utilization examples Up: 3.2 Multi-block method Prev: 3.2.4 Module COLIBR Index Contents
3.2.5 Preprocessor COLIXX
This preprocessor is used to create a command file of the same type as preprocessors APNOXX, APN3XX , etc. This file is completed by a set of question/responses and contains the following values:
Remarks:
