Modulefpreviousupnextcontentsindex[BIG][Normal][small]
Next: 1.3.2 Introduction of a curve Up: 1.3 Main ideas Prev: 1.3 Main ideas Index Contents
1.3.1 The NOPO data structure
The internal representation of a mesh must allows us to find a particular value (quantity stored in the representation) rapidly, or to calculate a value easily from information presented (quantity deduced from stored information). A mesh is therefore, in general, an assembly of values and arrays of values containing the set of geometric elements which constitute it. The following information is necessary for each element:
The MODULEF code stores this information in a NOPO data structure, constituting the natural interface between the different mesh modules.
Remark:
