![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
Next: 2.4 Changing the type of a
Up: 2 Manipulation of solutions
Prev: 2.2 Symmetrization and "gluing together" of
Contents
The solution of a parabolic problem by a variable time-step method leads to computation of the solutions
at times a priori unknown. The aim of module INTERQ is therefore to interpolate
these solutions to obtain a B structure containing the solutions at those times selected.
SUBROUTINE INTERQ(M,XM,NQ,NFB,NIB,PAS,NPAS,T0,TSAV,NFBS,NIBS)
C +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
C SUBROUTINE INTERQ . SINGLE PRECISION
C AIM : INTERPOLATE TO THE ORDER NQ THE SOLUTIONS RESULTING FROM
C EVO*GE(RK)
where
- M and XM represent the super array,
- NQ is the order of interpolation, it also encodes the manner in which the solutions is saved:
- 1
NQ
10: interpolation of the order NQ and saves the solution at a specific time TSAV,
- 11
NQ
20: interpolation of the order NQ - 10 and saves the solution at all time steps,
- NFB, NIB are the file numbers and the level of structure B resulting from the transient module,
- PAS is the time step,
- NPAS is the number of time steps (initial solution included),
- T0 is the initial time,
- TSAV is not used if NQ > 10, otherwise it is the time at which we want to save the solution. The value of
time, obtained after T0, PAS and NPAS, is defined by:
- NFBS, NIBS are the file number and level of structure B on exit.
The solution of a parabolic problem by an arbitrary method can, in certain cases, lead to
computing the solutions in two overlapping time intervals
and
The aim of module UNIONB is therefore to form a solution in the interval
by removing the intersection.
Several options are available. To describe them, let us consider the following example:
- the first structure B contains the solutions at times
while an associated array contains the values of
- the second structure contains the solutions at times
therefore
- the concatenated structure contains the solutions at times:
if we choose the truncation option in increasing order. Its associated array
contains the values of all these times.
if we choose the truncation option in decreasing order. Its associated array
- the concatenated structure contains the solutions placed end-to-end, if this option is
chosen
Preprocessor UNIOXX calls module UNIONB which performs the concatenation.
SUBROUTINE UNIONB(M,XM,NFB1,NIB1,NFB2,NIB2,JOPTIO,NFBS,NIBS)
C SUBROUTINE UNIONB . SINGLE PRECISION
C AIM : GLUE TOGETHER 2 I.D.S. B INTO A SINGLE O.D.S. B
where
- NFB1, NIB1 are the file number and level of the first B structure,
- NFB2, NIB2 are the file number and level of the second B structure,
- JOPTIO is the truncation option:
- 0
- : place end-to-end
- 1
- : increasing order according to the last associated array,
- 2
- : decreasing order according to the last associated array,
- NFBS, NIBS are the file number and level of the output structure B.
Contents
