Next: 2.8 Inquiring about D.S.
Up: 2 Manipulation of solutions
Prev: 2.6 Computing the stresses (D.S. TAE)
Contents
Preprocessor FLUXXX constructs D.S. TAE of flux or temperatures obtained by combining the element flux and temperature arrays of D.S. TAE, constructed in conjunction with the element matrices and RHS, and D.S. B containing the temperatures or flux, obtained during the computation of the solution of the thermal problem under consideration.
The finite elements possible are those for which, in the temperature formulation, we compute a flux element array and those, in the flux formulation, for which we compute a temperature element array.
Module FLUXTH, called by FLUXXX, computes the flux or temperature in each element. For a two-dimensional problem (the visualization of the three-dimensional case has not been implemented), structure TAE resulting from FLUXTH is used to visualize the flux or temperatures (see TRSTXX in part II of this user guide).
Program FLUXTH has the following form:
SUBROUTINE FLUXTH(M,XM,NFBE,NIBE,NFTAE,NITAE,NFNDL1,NINDL1, + NFTAES,NITAES,NTTAES,INDICA) C ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ C MODULE FLUXTH : COMPUTE THE FLUX OR TEMPERATURES DURING THE C -------------- RESOLUTION OF A THERMAL PROBLEM FROM THE ELEMENT C FLUX OR TEMPERATURES AND THE SOLUTION C ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
where
The input files required are NFBE, NFTAE and, in certain cases, NFNDL1. The output file is NFTAES.
There is no input data required specifically for this module except when NTTAES is non-zero. In this case, the following input is required:
Loop I from 1 to NTTAES
The output structure, TAE, is described in [MODULEF User Guide - 2].
REMTXX is used to compute the temperatures of mixed elements. REHPXX is used to compute the temperatures of primal hybrid elements (only TRIA HP12 is treated).
