Next: 8.3 List of devices available
Up: 8 Adapting a new terminal
Prev: 8.1 Adapting a new input terminal
Contents
The link between FORTRAN 3D and the output terminals is made by two intermediary subroutines, PERFGN and ITRCTG.
Subroutine ITRCTG was presented in the previous section. Subroutine PERFGN serves as interface between the graphics software, FORTRAN 3D, and your basic device.
PERFGN : ------ SUBROUTINE PERFGN(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING) CHARACTER *(*)STRING REAL V1(*), V2(*), V3(*) INTEGER ICH(*) include 'data_f3d.ins' GOTO(1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11), IDEVIC C IF IDEVIC=0 ASSIGN THE NUMBER OF DEVICES TO ICH(1) IF(IDEVIC.EQ.0)THEN C ICH(1) = NUMBER OF DEVICES AVAILABLE ICH(1)=11 RETURN ENDIF CALL PERIFX(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING) RETURN 001 CONTINUE C APOLLO CALL PERIF5(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING) RETURN 002 CONTINUE C LASER_WRITER(POST_SCRIPT) CALL PERIFD(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING) RETURN 003 CONTINUE C X_WINDOW_V11 CALL PERIFX11(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING) RETURN 004 CONTINUE C TEKTRONIX_4014 CALL PERIF1(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING) RETURN 005 CONTINUE C APOLLO_5 CALL PERIF5(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING) RETURN 006 CONTINUE C PRINTER CALL PERIF7(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING) RETURN 007 CONTINUE C VERSATEK_SPECTRUM_V80 CALL PERIF8(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING) RETURN 008 CONTINUE C VERSATEK_V80 CALL PERIFC(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING) RETURN 009 CONTINUE C TEKTRONIX_4107 CALL PERIFE(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING) RETURN 010 CONTINUE C TEKTRO_4105 CALL PERIFN(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING) RETURN 011 CONTINUE C PHIGS CALL PERPHG(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING) RETURN END
For an arbitrary driver, the parameters are:
The utilization of these variables depends on INSTRU (see below).
To use a graphics terminal, which is not yet supplied on the MODULEF magnetic tape, the user needs to write program PERIF* (see below) and include a call to subroutine PERFGN in it.
Parameter INSTRU has very particular effects if it is negative:
if(INSTRU.lt.0)then {interrogation du device} if( INSTRU.eq.-1)then c print on i1= number of order call wchari(i1, 'PERIPHERIQUE XXX') return elseif(INSTRU.eq.-2)then c definition of the call parameters with dialogue c we assign, using dialogue, the call parameters c that we store in ICH(1), ICH(2), ... STRING return elseif(INSTRU.eq.-3)then c default parameters (without dialogue) ICH(1)=std { affichage standard : plein ecran } ICH(2)=2 { couleur du fond} STRING='blabla' return endif endif call wchari(INSTRU, ' est une valeur incomprehensible') return GOTO indexe selon les valeurs >0 de INSTRU goto(1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22, + 23,24,25,26,27,28,29,30,31,32,33,34,35), INSTRU
The different tasks to be performed, referenced by INSTRU, are described below:
INSTRU = 1 : INITIALIZATION OF THE TERMINAL (DEVICE) ---------- IN : I1 : number of the active terminal ICH(*) and STRING : supplementary information for certain terminals All variables used are initialized by default (for example: line type, text size, ...). INSTRU = 2 : DEFINITION OF THE GRAPHIC CHARACTERISTICS (LIGH3) ---------- IN : I1 : intensity (if >= 0 assign) I2 : blinking (0 no, 1 yes) (if >= 0 assign) if stereo ( right=4 / left=2 ) I3 : color number in the color table (if >= 0 assign) INSTRU = 3 : DEFINITION OF LINES (DRAW3) ---------- IN : I1 : line type (full, dotted ...) define : type = I1 if I1 < 0 no lines plotted V1(1) : line thickness in mm. (if >= 0 assign) INSTRU = 4 : PLOT A LINE SEGMENT (LIN2TO, LIN3TO, ...) ---------- IN : V1(1) : abscissa of the beginning of the segment V1(2) : ordinate of the beginning of the segment V2(1) : abscissa of the end of the segment V2(2) : ordinate of the end of the segment if type < 0 no plot INSTRU = 5 : PLOT TEXT (TXT2D, TXT3D, ...) ---------- IN : I1 : number of characters in the text V1(1) : abscissa of the beginning of the text V1(2) : ordinate of the beginning of the text STRING : the text if type < 0 no plot if I1 = 1 and STRING(1:1) has a set of centerable characters ( O o X x + * 0 ) center the character. INSTRU = 6 : START OF A DESIGNATED ZONE (DEBAS) ---------- IN : I1 : zone identifier INSTRU = 7 : END OF DESIGNATED ZONE (FINAS) ---------- INSTRU = 8 : TEXT PLOT CHARACTERISTICS (DRW3TX) ---------- IN : I1 : number of the character font available i1=0 look for the font with the size closest to that chosen i1#0 use font i1 V1(1) : character size in cm. V2(1) : text angle w.r.t. the horizontal (as a fraction of pi/2.) INSTRU = 9 : START OF A FACET (DEBFAC) ---------- IN : I1 : = 0 : external contour, 1 hole INSTRU = 10 : END OF FACET (FINFAC) ---------- plot the facet INSTRU = 11 : CLEAR SCREEN (CLEAN) ---------- all existing plots are deleted INSTRU = 12 : DISPLAY OF A SEGMENT. HIGHLIGHT (DSPLAY, HIGHLT) ---------- I1 : 0 = normal display 1 = highlight (blinking ...) ICH(1) = segment number INSTRU = 13 : OPENING A SEGMENT (OPENG) ---------- ICH(1) = segment number a segment represents a sequence of graphical instructions defined between openg and closeg. INSTRU = 14 : CLOSING A SEGMENT (CLOSEG) ---------- INSTRU = 15 : KILL A SEGMENT (KILL) ---------- ICH(1) = segment number INSTRU = 16 : REMOVE A SEGMENT (REMOVG) ---------- ICH(1) = segment number INSTRU = 17 : INQUIRE SCREEN SIZE (SZSCRN) ---------- OUT : V1(1) = abscissa of the lower left-hand corner in cm. V1(2) = its ordinate in cm. V1(3) = abscissa of the upper right-hand corner in cm. V1(4) = its ordinate in cm. The screen is thus defined in cm. INSTRU = 18 : INQUIRE IF SEGMENT EXISTS (INQEXS) ---------- IN : ICH(1)= segment number OUT : I2= 0 if the segment exists, 1 if not INSTRU = 19 : LIST OF EXISTING SEGMENTS (INQNXS) ---------- IN : I1 = 1 initialization of the search I1 = 0 request next segment number OUT : if I1 = 0 I2 = 0 if there is a next segment ICH(1) number of this segment I2 -= 0 if there is no segment following INSTRU = 20 : UPDATE SCREEN (UPDATE) ---------- INSTRU = 21 : END, CLOSE DEVICE (ENDDEV) ---------- IN : I1 : terminal number INSTRU = 22 : GO TO STEREO MODE (STEREO) ---------- IN: I1=1 (on) I1=0 (off) OUT: I2 =0 stereo I2-=0 no stereo INSTRU = 23 : CURRENT COLOR (INQCOL) ---------- OUT : V1(1), V2(1), V3(1) reals between 0. and 1. giving R G B (proportion of Red, Green, Blue) INSTRU = 24 : SET CURRENT COLOR (SETCOL) ---------- IN : set the current color equal to the value in the array closest to (V1(1), V2(1), V3(1) INSTRU = 25 : NUMBER OF COLORS (INBCOL) ---------- OUT : I1 : number of colors possible (background color and at least the other : I1 >= 2) INSTRU = 26 : DEFINE THE COLOR ARRAY (SETTBC) ---------- IN : Set V1(1:), V2(1:), V3(1:) [0...1] in the color array between indices I1 and I2 inclusive. Indices I1 and I2 varies from 0 to nbcolo-1. OUT : I3 = 0 assignment performed I3 = -1 table not modifiable INSTRU = 27 : NUMBER OF COLORS AND ARRAY (INQTBC) ---------- OUT : returns in V1(1:), V2(1:), V3(1:) [0...1] the current color array between the indices I1 and I2 inclusive. Indices I1 and I2 varies from 0 to nbcolo-1. INSTRU = 28 : HARD CLIP FOR TEXT (CLIPHD) ---------- IN : V1(1) min in x of the zone, in cm. V1(2) max in x V1(3) min in y V1(4) max in y I1 = 1 clip, 0 if not INSTRU = 29 : SELECTIVE DELETION (INQFAC) ---------- OUT : I1 : 0 if selective deletion is possible, 1 if not INSTRU = 30 : EXISTENCE OF INPUT (INQCUR) ---------- OUT : I1 : 0 if there is input at the cursor (or other), 1 if not If there is input we keep the same terminal number (see ITRCTG : adapting to a new input terminal) INSTRU = 31 : MAXIMUM TEXT QUALITY (INQMQT) ---------- OUT : I1 =0 if the maximum text quality is HARD (le text soft est plus mauvais que le hard) =1 if the maximum text quality is SOFT INSTRU = 32 : TEXT CENTERING (CTRTXT) ---------- IN : V1(1) = alpha position in a box (0., 0.) (1., 1.) V1(2) = beta of the center of the text in x (alpha) and y (beta) : alpha and beta between 0. et 1. By default alpha = beta = 0. INSTRU = 33 : INQUIRE MAXIMUM NUMBER OF SEGMENTS MANAGED (INQSGM) ---------- OUT : I1 = maximum number of segments managed (0 = none) if i1 >0 this signifies that ALL instructions are managed correctly: === 12 DSPLAY 13 OPENG 14 CLOSEG 15 KILL 16 REMOVG 18 INQEXS 19 INQNXS INSTRU = 34 : RETURN THE NUMBER OF THE CURRENT COLOR (INQNCO) ---------- OUT : I1 = number of current color INSTRU = 35 : hardcopy (HARDCP) ---------- IN: I1 = choix1 (if different hardcopy terminals) I2 = choix2 (if different material possibilities)
Inspired by the programs already proposed, we define the different actions as a function of the possibilities offered by the graphics terminal at our disposal.
The fictitious subroutine, PEREXE, residing in library perf-example can serve as a model when creating the output program for a new device.
In addition, a certain number of subroutines were written to aid with a quick implementation of the drivers (see chapter 7 and the index):
GETUNF RCHARS RINTG RREAL CHARI WCHARS ZCENTR ZCOLOR ZFNDTC ZGNUM ZGTEXT ZSTROK ZTXT
