Next: 1 Mesh manipulation
Up: Part I: Numerical processing
Prev: Part I: Numerical processing
Contents
Part I consists of several chapters:
- Chapter 1
- gives an overview of some of the possibilities to manipulate a D.S. NOPO.
- Chapter 2
- describes the tools to construct, or manipulate a D.S. B. It describes the
computation of stresses for an elasticity problem, as well as the computation of the flux or
temperatures in the case of a problem using fixed mixed elements. The computation of reaction and
interface forces is also found in this chapter, as is the calculation of error norms.
- Chapter 3
- summarizes the different manipulations corresponding to matrices and eigenvalues and eigenvectors
of a system. The formatting/unformatting operations of a D.S. is also described, as well as the manner in which a
D.S. NOPO is created from two files containing its mesh description.
Contents
