Next: Part II: Graphics
Up: 3 Manipulation of structures and miscellaneous
Prev: 3.7 Eigenvalues and eigenvectors of a
Contents
Compression of a D.S. MUA (module CCMUA) or AMAT (module CCAMAT).
SUBROUTINE CCMUA(M,RAPORT,NFMUAE,NIMUAE,NFMUAS,NIMUAS) C +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ C AIM : COMPRESS THE I.D.S. MUA BY RETAINING ONLY THE COEFFICIENTS C --- A(I,J) IN EACH ROW I BELOW THE 1ST SUPERIOR OR EQUAL TO C ABS(A(I,I)) * RATIO FOR I=1,...,NTDL C +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
where
SUBROUTINE CCAMAT(M,RAPORT,NFAMAE,NIAMAE,NFAMAS,NIAMAS) C ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ C AIM : COMPRESS THE I.D.S. AMAT BY RETAINING ONLY THE COEFFICIENTS C --- A(IJ) SUCH THAT ABS(A(I,J)) >= RATIO * ABS(A(I,I)) I=1,...,NTDL C ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
where
